Fitting Two Metal Pieces Together - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-29-2018, 01:34 PM   #1
Rewards Points: 2
Fitting two metal pieces together
I have a metal clothesline that rusted out at the threads, so the T shaped support structure will no longer fit into the metal fitting cemented in to the ground.
I am hoping there is an easy fix... maybe some sort of fitting that will connect the two pieces. The pipe at the end of the T-structure is 4" in diamater. The opening of the base piece is 5.5".
THANK YOU!
jsneddon is offline   Reply With Quote
Old 06-29-2018, 05:53 PM   #2
Rewards Points: 8,432
Re: Fitting two metal pieces together
A picture would help. Not sure how many posts you need to post photos. You could always put the photo in your "album", or post link to external site.
But I think basically, you would have to take the loose piece to a shop that does welding, and have them weld something on. It might be a pretty loose fit, but a screw can keep it from turning. ( Of course, you could always get somebody with a portable welder to come to your place and weld it up, but that is going to a little expensive)
If the pieces are threaded, there is a good chance its made from Schedule 40 steel pipe. You can google galvanized pipe dimensions to get accurate sizes, or fittings to see what is available. But I don't see how a standard fitting is going to help if your piece is rusted away.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
jsneddon (06-30-2018)
Old 06-29-2018, 06:04 PM   #3
Rewards Points: 18,118
No there is not magic fitting for this one.
May be cheaper and faster to just make a new one out of 2" galv. pipe.
4" was way over kill.
Old 06-30-2018, 07:41 AM   #4
Rewards Points: 4
I disagree with that. I came from a very rural area, and all the poles there were 4".ive seen a couple of 2" poles bent. It's a lot of weight swaying in the breeze, when you think about it. Of course that 5" upright he has is definitely overkill.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline   Reply With Quote
The Following User Says Thank You to t.carpenter00 For This Useful Post:
Old 06-30-2018, 09:23 AM   #5
dd57chevy's Avatar
Rewards Points: 2,826
If you could find a steel tube (at a steel & iron shop) that would fit over or inside your vertical pipe , you could make a new one . The trick would obviously be getting a new tube the right size
dd57chevy is offline   Reply With Quote
The Following User Says Thank You to dd57chevy For This Useful Post:
Bad solder joints, fixable? ponch37300 Plumbing 10 11-18-2015 05:36 AM
Replacing latch on metal framed garden gate tinan General DIY Discussions 2 09-06-2015 03:26 PM
Voltage in the Shower Deacon98 Electrical 32 01-19-2012 05:14 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 01:45 PM
