Fires Starting In The Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree34Likes
Old 06-07-2019, 04:39 PM   #1
retired framer
Rewards Points: 14,034
Fires starting in the garage
Fires starting in the garage are also among the most destructive house fires. Garage fires tend to spread more rapidly than fires starting in other areas of the house, and they cause more property damage than other types of fires.
So why when the house and garage attached why is there no smoke alarm in the garage?
GrapeApe likes this.
Do not use flat bottom gables with scissor trusses.
Old 06-07-2019, 04:43 PM   #2
retired framer
Re: Fires starting in the garage
And CO detectors.
Old 06-07-2019, 07:13 PM   #3
Rewards Points: 1,728
I agree; I've thought of putting one in my garage. The only problem might be false alarms from auto exhaust. Also considered building some kind of garage cabinet for flammables.
ChuckF. is offline   Reply With Quote
Old 06-07-2019, 08:07 PM   #4
Rewards Points: 322
Why isn't there a CO detector that OPENS the garage door?
Let it Snow is offline   Reply With Quote
Old 06-07-2019, 09:00 PM   #5
Rewards Points: 626
I actually have a couple in my garage already. One is a 2x2x3' high cabinet I got from a job I had working with the auto industry a LONG time ago. The other one is 6"x4'x4' that the prior owners left. (They actually left 2 and I gave one to the neighbors.
I use them for any kind of chemical from car care to spray paint lawn and garden chemicals. Anything hazardous for flammable.
Looking for them now, I guess I should have sold the one I gave away.
If you do go get to building one, which makes more sense, I would suggest wrapping it in 26 ga or heavier steel. I got that from something Neal posted in another thread. It had to do with ductwork sheetmetal going through a garage.
I know a little bit about a lot of things. What I don't know, I research.
The only stupid question is the one you DON'T ask!
Most of all, have fun! It ticks people off and ruins their day.
ktownskier is offline   Reply With Quote
Old 06-07-2019, 09:50 PM   #6
Rewards Points: 3,958
I know four different people who had house fires and three of them started in the garage. One was a dumba$$ cleaning parts in a tub of gas with a space heater running but the other two were caused by electrical fires in cars parked in the garage.
Have to admit, it never occurred to me to put a smoke detector in the garage but it does make sense.
Nealtw likes this.
stick\shift is offline   Reply With Quote
Old 06-07-2019, 10:43 PM   #7
Msradell's Avatar
Rewards Points: 740
We've had heat detectors (135 F) in the garages of our last 3 homes, they give a margin of safety without the risk of false alarms from a smoke detector in that area. I wonder how sensitive a CO detector is in relation to the amount of CO that a car emits when it's being started? I know many of them are very sensitive.
We also have a heat detector in the attic (185 F).
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-07-2019, 10:49 PM   #8
retired framer
We should always have the door open when running the engines.
I like the automatic door opening idea.
Old 06-07-2019, 11:06 PM   #9
Rewards Points: 828
Smokes and heats have a life span of 10 years. But I have seen smokes and heats still working after 20-25 years. Not a bad idea to put a vacuum hose up their once in a while.
fireguy is offline   Reply With Quote
Old 06-07-2019, 11:12 PM   #10
retired framer
False alarms are free practice run to get the family out so you can develop a better plan for egress, they are a plus to have when no one has planned for it.
Old 06-08-2019, 05:48 AM   #11
Rewards Points: 80
Smoke detectors that last more than a couple years? Interesting to say the least.
ChuckTin is offline   Reply With Quote
Old 06-08-2019, 08:49 AM   #12
HenryMac's Avatar
Rewards Points: 788
Filth and spiders wreak havoc with smoke alarms. That's why you rarely see them in garages.
Case in point:
We had smoke alarms in our garage at our last home, part of the ADT security system.
Spiders would get into the alarm and trigger false alarms.
We were on vacation, I got a call from the fire department. They were at my house, in front of the garage, and asked for permission to break the door down.
I asked if they could smell smoke? They said no.
I asked how long they had been there? 10 minutes
I told them I appreciated their efforts, but no, I did not want them to break the door down.
ADT fiddled with the alarm for about month after that and eventually we disarmed it.
CodeMatters likes this.
HenryMac is offline   Reply With Quote
Old 06-08-2019, 09:11 AM   #13
Rewards Points: 805
CO detector in a garage would have to be specifically designed for garage use. They would have to be set to ignore huge spikes of CO from cars starting up cold for example.
Smoke sensors may be a problem as well. Tool operation, sweeping, etc. would give frequent false alarms. Also, a garage sensor would need to operate in more extreme temperatures (-20 to +120 deg F).
I do like the idea of a heat sensor. Would have to be wired so that the alarm went off inside living space as well since it might not be heard otherwise.
Fotmasta likes this.
chiraldude is online now   Reply With Quote
Old 06-08-2019, 09:20 AM   #14
Rewards Points: 6,622
I have wondered the same thing. I think HenryMac gave the basic answer.
I find that Kidde (manufacturer) recommends:
The installation of heat alarms in attics, furnace rooms or garages is recommended, since these locations occasionally experience conditions that can result in improper operation of smoke alarms.
...which leads to the next question -- why aren't heat alarms required in garages? Maybe because of the high temps that can be reached in a garage. I bet my garage can hit 120 at certain times of the day in the summer. I can just imagine how hot it can reach in a Phoenix garage.
SPS-1 is offline   Reply With Quote
Old 06-08-2019, 09:39 AM   #15
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,658
Some good ideas and thoughts above ^^^^^^^^^^^^^^^^^
At least, I have always had a smoke alarm in the garage. I do get a nuisance trip now and then when I'm doing something.... but it seems like a small inconvenience overall.
Unfortunately, my fire alarms are not inter-wired together, and I don't know an electrical fire in the garage would be heard well enough way back toward our bedrooms.
(I am not per-se a proponent of some of our code requirements, but it seems to me to be a very small cost and a significant safety advantage to code require new construction to have inter-wired systems INCLUDING the garage.)
JMO
MTN REMODEL LLC is offline   Reply With Quote
