Fireplace Surround - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-15-2013, 11:58 PM   #1
Fireplace surround
Hi,
I am remodeling our fireplace surround. It had tile around it and I successfully demoed that. Now the "backerboard" is weak in places and I can press it in easily with 1 finger. I am thinking I need to tear out all of this "backerboard". I say backerboard as I don't really know what it is. Should I replace it with wonderboard? Ultimately my goal is to have a paintable fireplace surround, no tile or stone with a modern look. Can I paint the wonderboard as if it were drywall? Can the wonderboard butt up against the fireplace? It is a gas fireplace and has not visable vents in the front, I imagine it all goes up thru the chimney that I know is for sure there.
DIYtrophywife is offline   Reply With Quote
Old 09-16-2013, 07:25 AM   #2
Retired Moderator
Rewards Points: 7,174
Post a picture if you can---you will have trouble getting a smooth ,printable surface with Wonder Board---Hardie Backer or drywall might be better---but we need to see what you have going on.--Mike----
Old 09-16-2013, 09:51 PM   #3
photos
Thanks for your input. Is drywall safe to put around the fireplace? Photo 1 is of the whole surround. I started pealing back the gold "wallpaper" type stuff, as I had said in my last post it was weak in some areas. It appears the person who did this fireplace surround originally mudded the whole thing and it is now dry and crumbling (photo 2). I believe I need to tear out all the gold "wallpaper" and all the crumbling mud. Then I believe I am down to the original framing. What do I put in around the fireplace (black metal front) to get the final appearance a basic paintable wall like product (Photo 3).
Old 09-17-2013, 07:04 AM   #4
Retired Moderator
Yes,you can drywall right up to the face of the firebox----many codes ask for 5/8" thick--
Tags
fireplace , paintable surround , surround , wonderboard
Does this fireplace surround look bad? r.mills Building & Construction 5 01-18-2013 02:57 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Fireplace granite surround, what adhesive? bsmith6356 Remodeling 0 10-03-2010 07:35 PM
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 02:12 PM
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 05:37 PM
