Feedback On Pergola Ideas Please - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-21-2017, 09:23 PM   #1
Rewards Points: 6
Hi
Im looking for some feedback on a pergola plan.
I have never built one this large.
It will be approximately 14 to 16 feet wide by 14 to 16 feet long.
My plan is to have 3 6 posts and on top of them double up 2 2x 6 x 14 to 16 aligned parallel to a brick wall.
Along the brick wall I will attach 2 pieces of 2x6 and then attach hanging metal brackets and then run a series of 2x6 to from the wall to sit on top of the doubled up boards.
Does this sound ok?
1. Is there a standard height for a pergola?
2. Are 2x6 boards fine?
3. For the boards running from the wall to the doubles up boards whats their spacing apart? 16
4. Do I need 3 support posts for a 14-16 support posts or is two fine?
I have mocked up my idea in a diagram.
Thanks for the help.
Thanks for the feedback
acolic is offline   Reply With Quote
Old 09-22-2017, 05:46 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,336
Re: Feedback On Pergola Ideas Please
How do you plan on attaching your 2x6's to the posts? Bricks do not offer any structural stability. Can you not make this free standing? It would require cross bracing, but it won't infiltrate your home and possibly dislodge brick from their places.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-22-2017, 09:00 AM   #3
Civil Engineer
Rewards Points: 5,246
You don't say where you are located, so it is impossible to understand the loads on your pergola. Wind loads are usually the largest load on a structure with no roof, and maximum wind loads depends strongly on location. I am unclear how you selected lumber size, did you look at other pergolas, did you guess at the size. did you look at plans? If you think you might add a roof later, size of joists and beams will be different than if you plan on an open structure.
Old 09-22-2017, 12:11 PM   #4
Rewards Points: 6
Hi I live in Southern Ontario. I dont believe wind is an issue more likely snow. I saw other pergolas and thats where I got the 2x6 dimension. Im not saying thats correct though.
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Help! need pergola ideas Farmer Jane Building & Construction 6 06-14-2011 09:29 AM
Suggestions, ideas needed on building pergola Farmer Jane Building & Construction 0 06-10-2011 11:07 AM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 07:19 PM
Loo9king forward to ideas nanalane9 New Member Introductions 3 03-25-2011 09:07 AM
