Thread Tools | Display Modes |
#1 |
Rewards Points: 6
![]() Faucet set screws for Franke
I have a Franke "goose neck" bar-sink faucet. Lost set screw holding the goose-neck spout to the base .... are they all standard size? The spout pops out under water pressure. In Thailand now... no help here until I get back to US... I think model is discontinued.. 'tap diamante chrome'
any ideas to fix temporarily? ..can use cutter to turn wood screw into fla at the end? help please gary |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 6,096
![]() Re: Faucet set screws for Franke
Why not just take spout to hardware store and find a set screw. Certainly it will be a standard size, just don't know whether it will be US standard or metric.
The Following User Says Thank You to hkstroud For This Useful Post: |
ggk888 (10-14-2016)
Advertisement |
#3 |
Rewards Points: 6
Even Franke in Bangkok said they would order from Italy... be here in December.
I've tried all the Home Depot, Lowes, "look-alikes".. They just don't have any parts, bins of nails, srews etc. I've taken it locally(200miles south of Bangkok).. but no help.... Thanks again for the suggestion |
Advertisement |
#4 | |
Master General ReEngineer
Rewards Points: 1,790
![]() Re: Faucet set screws for FrankeQuote:
The Following User Says Thank You to Bondo For This Useful Post: |
ggk888 (10-14-2016)
#5 |
Rewards Points: 6
Very good idea... that knowledge is above my pay grade....all I've ever done is fix things using only my math and finance degree... older I get the more things like you do mean more than advanced calculus...Ha, ha Thanks so much Gary
#6 |
Home Depot has set screws. They may not have the size you need but they have set screws. As the original source is Italy it will be metric.
The set screw for a faucet spout will be very small. Home Depot keeps small set screws in a cabinet in the hardware aisle. Ask for assistance. Since you have indicated that you are math and finance guru, I have to ask the following. Are you sure the set screw is missing? Are you sure that it is missing and not just loose? Pull spout off and look in the set screw hole. Do you see light. If not, the screw is still in there and just needs tightening. You will need a small Allen wrench to tighten it. |
Advertisement |
Tags |
faucet repair
franke faucet
set screw faucets
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Faucet without set screws | Big Ed LA | Plumbing | 9 | 10-20-2015 09:38 PM |
Changing faucet - reverse osmosis adapter | grand_canyon | Plumbing | 4 | 11-20-2012 11:29 PM |
New Moen Faucet still has sloooooow drip | straightsix | Plumbing | 4 | 11-05-2012 09:51 PM |
Another "Kitchen faucet replacement" thread! :) | emperor_black | Plumbing | 3 | 07-27-2009 11:44 PM |
Screws vs Nails in Interior framing project | alexz | Building & Construction | 2 | 07-05-2006 06:58 AM |
