Eliminate Bulkhead Basement Entry - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By beejoe
  • 3 Post By georgemcq
  • 2 Post By AllanJ
Old 04-03-2019, 05:29 PM   #1
Rewards Points: 98
Not likely diy, but have you ever heard of a walkout bulkhead basement being eliminated? Like patch hole in foundation and backfilling the entry?
beejoe is offline   Reply With Quote
Old 04-03-2019, 05:37 PM   #2
retired framer
Rewards Points: 6,256
Re: Eliminate bulkhead basement entry
I would make it a window with a window well maybe.
Do not use flat bottom gables with scissor trusses.
Old 04-03-2019, 05:37 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,556
Pictures of what you are seeing are going to help illicit a bunch more responses here.
Old 04-03-2019, 05:41 PM   #4
Rewards Points: 98
No photo of mine handy, but just picture a basic basement entry, abut 7' deep, with stairs and an overhead bilco door... drain at the foot of the stairs. Standard size door cut into poured foundation.
Nealtw likes this.
Old 04-03-2019, 10:56 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 988
I can't see why not. I would think you would have to fill the hole in with block. How to properly tie it into the poured wall I'll leave to others. The new wall section should be waterproofed. Assuming the well drain is tied into a perimeter drain, you would want to ensure the that perimeter drain is reconnected so it is continuous.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 04-04-2019, 09:56 AM   #6
Maintenance / Locksmith
Rewards Points: 296
Can I ask "why" you want to eliminate this entrance. Could be a real problem replacing HVAC equipment or anything large down the road for you or a future owner.
Bondo, Yodaman and Mike Milam like this.
georgemcq is offline   Reply With Quote
Old 04-04-2019, 03:12 PM   #7
Rewards Points: 2,862
Don't do it. Almost always it is a bad idea to decommission, close up, and fill in a basement entrance with a bulkhead because this is a convenient feature for almost every homeowner or resident.
Bondo and Yodaman like this.
AllanJ is online now   Reply With Quote
Old 04-04-2019, 07:18 PM   #8
Rewards Points: 108
I have a bulkhead door also. I also have my boiler and hot water heater in the basement. It would be a major PIA to try and get those things out of the house through the interior of my house.
woodypecker is offline   Reply With Quote
Drywalling bulkhead and wall repair after basement reno Simon96Taco Drywall & Plaster 9 11-22-2013 11:38 PM
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 09:27 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
outdoor shed entry for basement mamut0o1 Roofing/Siding 3 02-09-2010 11:57 AM
