Electrical Wire In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-11-2018, 11:23 AM   #1
Rewards Points: 92
Electrical wire in garage
Hi
This is probably a silly question for most of you but what is right way to cover up / get rid the remaining electrical wire?
I tried yanking the cable but it seems very tight and I am afraid of damaging the wall / siding.
Should I just snip the cable as close to the wall as possible on both sides and then caulk it?
Thanks.
007noob is online now   Reply With Quote
Old 10-11-2018, 11:26 AM   #2
retired framer
Rewards Points: 408
Re: Electrical wire in garage
There is likely a staple holding it. I would cut it off and stuff it in the hole.
Old 10-11-2018, 12:52 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 29,300
Cut off close and push stub into wall with screw driver.
Electrical Wiring for Separate Garage HomeGuy2 Electrical 11 03-15-2013 11:50 PM
Electrical Outlet in my garage killed my garage door opener. thorxes Electrical 5 02-26-2012 04:17 AM
Need some help with garage electrical issue Holt Electrical 25 06-21-2010 01:59 PM
Multi Wire Branch to 2 outlets in garage mw_bama Electrical 4 06-03-2010 07:31 AM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 01:40 AM
