Dutch Pot - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-14-2015, 05:30 PM   #1
ac5me's Avatar
Rewards Points: 28
Dutch Pot
I have a Dutch pot I inherited from my father and it has a 3 inch crack near the top rim. NO welder will touch it as it is too much trouble. I just want to be able to cook a jambalaya in it. How about a high temp epoxy? After curing it will it be safe?
ac5me is offline   Reply With Quote
Old 11-14-2015, 10:00 PM   #2
Msradell's Avatar
Rewards Points: 976
The epoxy will work if you want to use it for something decorative but won't work if you want to cook in the pot. The problem is the expansion rate between the epoxy in the material the pot is made from a radically different and as it heats up the crack will form again.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 11-15-2015, 12:22 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 592
Check out this link.
http://www.ehow.com/how_4964927_seal...cast-iron.html
I used it to seal a cracked engine block, worked like a charm.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-15-2015, 06:27 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 182
Ayuh,.... As in a cast iron dutch oven type a pot,..??
I agree with Jim 'bout fixin' motor blocks with JB weld, but motor blocks only run from ambient temps to 'bout 180°,....
Donno the temp extremes JB weld can handle, as a cast iron pot will see temps Much higher than 180°,.....
I suggest ya use Dad's ole pot for decoration, 'n buy a new dutch oven for cookin' purposes,....
I've brazed cast iron fryin' pans, 'n yes, it's a slow pain in the butt to heat it, braze it, then cool it slowly enough as to not crack it again near the weld,....
Cast iron can be brazed, or stick-welded with nickle weldin' rod,...
I've got an ole round oak potbelly stove firebox out in the garage now that I'm gonna try to fix for a friend of a friend,...
Try is the key word,.....
The break is 'bout a foot long, 'n can only be welded 1/4" at a time, then allowed to cool,....
A very long slow tedious process,....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
BigJim (11-15-2015)
Old 11-15-2015, 07:01 AM   #5
Rewards Points: 18,376
Another trick is to drill a hole at the end of the crack before brazing.
It will help keep the crack from spreading.
Dutch boy -still tacky 6 weeks thburd Painting 13 05-26-2013 09:01 PM
The Dutch have the right idea. DangerMouse Off Topic 20 03-13-2013 09:51 AM
How to Insulate finished attic room that has a Dutch hip that connects the side attic Lascaux Insulation 2 06-05-2012 08:19 AM
help can you put a screened porch on a dutch colonial? kroe Roofing/Siding 1 04-15-2010 07:29 PM
Is Dutch Boy Exterior Oil-Primer OK? thegonagle Painting 1 09-30-2008 06:07 PM
