Drywall Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By chandler48
  • 1 Post By Yodaman
  • 1 Post By Nealtw
Old 06-25-2019, 06:47 PM   #1
Rewards Points: 40
Drywall Question
Hi just wanted some advise, I'm continuing my basement where someone left off, as you can see in the photos (hopefully they attached) the Pink Foamboard is attached in front of the studs to the studs. My question is, id like to continue with this process but I wanna make sure drywall can be attached to the foam over top of it. I've read there are adhesives to do it along with screwing it in through the foam then stud.
Any help would be great!
Rob
Drywall Question-img_20190625_182300.jpegDrywall Question-img_20190625_182235_hdr.jpegDrywall Question-img_20190625_182140.jpeg
Sent from my Passport using Tapatalk
Estranged is offline   Reply With Quote
Old 06-25-2019, 07:25 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,340
Re: Drywall Question
You'll have to use screws long enough to penetrate sheetrock/foam and go into the studs at least half way. 2" based on 1/2 sheetrock, 1/2 foam. Regardless, the foam needs to either be removed or covered with sheetrock or other wall covering.
Yodaman likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-25-2019, 07:33 PM   #3
Rewards Points: 40
Thanks Chandler, so placing Drywall right on top of the foam is an option then? With the proper things Thanks again
Rob
Sent via My BlackBerry Passport using the Tapatalk Google App
Old 06-25-2019, 07:35 PM   #4
Property Mgt/Maint
Rewards Points: 7,626
Can not tell how thick the foam is, but after clearing the drywall and the foam, should have about 1" min of screw into the stud.
The most common drywall screw is 1 5/8", but they come in longer lengths for such applications as yours.
Estranged likes this.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 06-25-2019, 07:43 PM   #5
Naildriver
chandler48's Avatar
Foam states 1/2", so if it is a single layer, 2" screws should work. The one thing you will encounter problems with is the receptacle and switch settings. They are 1/2" too shallow now and you will either need to use extension boxes or rings to bring them to the new depth with the sheetrock. You cannot leave a gap like that.
I just noticed you have metal studs. You will need to use self drilling sheetrock screws to engage the metal. The other advice was based on wood studs.
Larry......
Old 06-25-2019, 07:46 PM   #6
retired framer
Rewards Points: 6,256
Sheetrock screws come in a fine thread for steel studs, I would use 2"
Do not use flat bottom gables with scissor trusses.
Old 06-25-2019, 07:56 PM   #7
Rewards Points: 40
Thanks everyone, yes it is half inch foam, the receptacles I have seem to be sticking out half inch or a bit more past the foam so I may be ok to do without the ext boxes but I will add if need be. I wasn't sure if this practice was common in the trade or not wise.
Thanks again everyone
Rob
Old 06-25-2019, 08:06 PM   #8
Naildriver
chandler48's Avatar
The insulation needs a vapor barrier. The foam is overkill. You're good.
Larry......
Old 06-25-2019, 09:44 PM   #9
Rewards Points: 40
Thanks Chandler great advice
Old 07-10-2019, 02:04 PM   #10
Rewards Points: 106
Romex in metal studs? Thought that had to be BX cable or is that only in commercial?
geenowalker is offline   Reply With Quote
Old 07-10-2019, 05:50 PM   #11
Naildriver
chandler48's Avatar
Romex is fine as long as it is protected as it passes through the metal as shown. Yes, AC is required on most commercials, except in Chicago and other places that require conduit.
Larry......
