Drywall Anchors To Install Bathroom Mirror - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-12-2014, 02:16 PM   #1
Rewards Points: 1,256
drywall anchors to install bathroom mirror
Hello
Is this type of anchors OK to install a 36" x 30" beveled mirror in a bathroom?
I would think so, but any advice is appreciated
Wall is drywall, and I will use the plastic clips included with the mirror
I was thinking to use 2 at the bottom, 2 on the top and 1 on each side
french_guy is offline   Reply With Quote
Old 09-12-2014, 02:27 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,814
What type? Don't see a link or pic.
Old 09-12-2014, 02:31 PM   #3
Well, I'm reattaching the picture
Old 09-12-2014, 02:48 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thosullwork.
XXX
Old 09-12-2014, 02:59 PM   #5
Rewards Points: 6,652
When I hung the mirror in our Bath. I used the ones that drill into the Drywall, and then there is a piece on the end, that turns out when you screw the screw into the anchor.
Old 09-12-2014, 03:10 PM   #6
I want to keep the holes small
Those anchors that srews into the drywall sometimes make a bump on the drywall itself, all around the head of the anchor
Old 09-12-2014, 04:53 PM   #7
(the original)
Rewards Points: 756
These are what I prefer when I can't hit a stud:
http://www.grainger.com/product/RED-HEAD-Anchor-4E824?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/4E824_AS01?$smthumb$
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Windows on Wash (09-15-2014)
Old 09-12-2014, 08:10 PM   #8
Rewards Points: 218
The ones that screw in to the drywall are easier to install if you drill a small 1/8" pilot hole first.
daveblt is offline   Reply With Quote
Old 09-15-2014, 01:08 PM   #9
I ended up using the EZ-Ancor “Twist & Lock” screw type anchors (plastic one, rated 50lbs)
Went very well with the 1/8”pilot hole...thanks Dave
Seems very strong
I wouldn’t use those without 1/8" pre-drilling…..
The Following User Says Thank You to french_guy For This Useful Post:
Old 09-15-2014, 03:22 PM   #10
How heavy is this mirror? I only use the Metal ones, since I have Gyprock in the rest of my home. Also them work well for towel racks. Since people tend to love to poll on the towel bar, while removing the towels.
Old 09-19-2014, 11:00 PM   #11
Jello Wrangler
Rewards Points: 539
Seems very strong
No need to predrill, just use the screw that comes with the anchor. Drive it in, back it it, drive in the anchor.
ChiTownPro is offline   Reply With Quote
Old 09-19-2014, 11:32 PM   #12
Bob Sanders's Avatar
Rewards Points: 2,536
I like that idea. The metal ones however don't require any hole at all which is why I don't bother with the plastic ones anymore.
Bob Sanders is offline   Reply With Quote
Old 09-19-2014, 11:40 PM   #13
They do if you have GypRock like I do. I always drill a pilot hole for the Metal ones. Otherwise, they would never go in. After 70+ years. Portland based Plaster gets very hard.
Old 09-20-2014, 01:00 PM   #14
Jello Wrangler
Rewards Points: 539
I have some metal ones in the truck, haven't tried with out some sort of pre-drilling. I'll give it a whirl on the next go around.
Install closet door over drywall Fixitdude Remodeling 3 09-06-2012 10:15 PM
2 drywall install questions. Fix'n it Drywall & Plaster 5 07-06-2012 10:24 PM
Bathroom Drywall jeepwillies Drywall & Plaster 11 05-03-2011 01:04 PM
large bathroom mirror DK75 Remodeling 4 04-18-2008 06:27 PM
drywalling bathroom / paperless drywall johnny331 Remodeling 7 10-17-2007 09:06 PM
