Drill Bit Size For Cabinet Handles Holes - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By SPS-1
Old 07-11-2016, 08:41 PM   #1
Rewards Points: 194
Drill bit size for Cabinet Handles holes
My pulls and knobs came with an 8-32 size machine screw and I wanted to ensure i drilled the right holes in my new cabinets, but i am a dope with drill bit sizes.
Any help is appreciated on drill bit size.
DeeEyeWhy is offline   Reply With Quote
Old 07-11-2016, 09:03 PM   #2
Rewards Points: 18,972
Re: Drill bit size for Cabinet Handles holes
Try 3/16".
The screw does not have to be tight in the hole, in fact a little bit loose is better so the holes in the handles line up easier.
Old 07-11-2016, 09:09 PM   #3
MT Stringer's Avatar
Rewards Points: 254
I seem to be the worlds' worst at guessing drill bit sizes. So I eyeball'em!
I pick the next size larger and drill a hole in a piece of scrap wood and make a test fit. Like Joe said, a little loose is a good thing. It will suck up tight when you screw it on.
MT Stringer is offline   Reply With Quote
Old 07-11-2016, 10:38 PM   #4
firehawkmph's Avatar
Rewards Points: 2,584
+1 on the 3/16" bit. I've installed quite a few kitchens, all with hardware, and that seems to be the bit I always use.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-12-2016, 07:16 AM   #5
Rewards Points: 10,804
If you are mounting a bunch, you may want to make up a drilling jig.
Msradell, ZZZZZ and jeffmattero76 like this.
SPS-1 is online now   Reply With Quote
Old 07-17-2016, 04:44 PM   #6
Rewards Points: 194
Thank you all, 3/16 bit worked like a charm
Old 07-18-2016, 08:54 AM   #7
Rewards Points: 3,014
I read this post (and the succeeding posts) and could not understand what was being discussed.
I saw "8-32 size", so I thought that this may mean 8/32" (which is strange, since that equates to 1/4")
Reading on, I realised that there was something very wrong with my interpretation of what was being discussed and, on searching on "8-32 size machine screw" found https://www.boltdepot.com/Product-De...x?product=1739, which enabled me to understand that this was a machine screw with a diameter of #8 with, seemingly, 32 threads to the Inch.
(While I wondered what a diameter of #8 may mean, a little bit of further reading indicated that, in "US machine screw diameters", #8 indicates 5/32")
I strongly suspect that what is mentioned here is actually what the "British" world would call a 5/32" Whitworth threaded item, which would comfortably fit into a 3/16" hole
It may be that US manufacturers may not wish to acknowledge their debt to the "Industrial Revolution", which originated in Britain.
Be that as it may!
However, I consider that it is a pity that dimensions such as these are quoted in such a "cabalistic" manner.
Over 95% of the world does NOT use obscure dimensions in such discussions. The only dimensions used elsewhere are SI.
FrodoOne is offline   Reply With Quote
Old 07-18-2016, 09:54 AM   #8
8-32 would be a spec for a .164" nominal body, 32 threads per inch.
The thread specs would be UNC (Unified National Course), per ASME definition and tolerances. I believe the #8 designation originated from the wire gage.
Agreed, metric designations much simpler. Only one standard pitch per size.
Ok for movers to use a power drill to re-assemble furniture? HomeLearner Tools 18 11-08-2014 09:13 PM
How to drill holes for lateral bracing for a deck. Bugman1400 Building & Construction 11 09-27-2014 03:34 PM
What size drill bit for a 5/8" Bolt? Matty16 Building & Construction 12 01-14-2014 12:46 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
what size drill bit? econdave General DIY Discussions 3 10-11-2007 05:23 AM
