Door Stop For Tile Baseboard - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 07:16 PM   #1
Door stop for tile baseboard
What kind of door stop should I for my bathroom which has tiled floors and baseboards? The rest of the house is spring baseboard door stops. Options I am considering include 1) Screwing into wall above baseboard with drywall anchor or going into stud (won't look nice being that high up). 2) Drilling into baseboard tile and then stud (I'm worried about breaking tile). 3) Floor mounted stop (Worried about breaking tile). I'm not sure if glueing anything to tile is an option for 2) or 3). Thanks.
djgrant is offline   Reply With Quote
Old 06-13-2011, 07:43 PM   #2
Carpenter
dtsman's Avatar
Rubber door knob stop for the door knob to hit.
dtsman is offline   Reply With Quote
Old 06-13-2011, 07:58 PM   #3
Thanks. I think we'd prefer something down near the floor that will be less visible. But I will definitely consider this. There are some simple white dome-looking things that go on a wall too, that don't look that bad.
Old 06-13-2011, 08:03 PM   #4
Rewards Points: 5,348
You can screw the doorstop into the door.
Ron
B. Franklin 1759
Old 06-13-2011, 08:29 PM   #5
That's not a bad idea. I have no idea what my doors are made of...well definitely wood of some sort. I'm 99% sure they are hollow. I'm not sure if that is literally hollow or if there is something in the middle. How to attach something to it? I guess I will have the same issues if I try to attach a towel rack or coat hook to the back of the door. I'm seeing references online to "hollow door anchors" and these look similar to drywall anchors. Never done this before, any advice is appreciated. I have used various types of drywall anchors a lot though, from the simple 10lb push in ones, to heavy duty toggle bolts.
Old 06-13-2011, 08:45 PM   #6
Rewards Points: 6,652
Just go with the hinge stops if not wanting to secure anything to the doors. As for the door stops, you would use a drill bit for drilling through tile, but first score the tile before drilling either through the floor, or the baseboard. Personally, I would opt for the hinge stop over anything.
Old 06-13-2011, 09:01 PM   #7
Hollow core doors have a solid wood perimeter frame. If you look at the door from the top, you will see how thick it is. Just screw the stop into the solid part. A pilot hole will make it easier.
Ron
B. Franklin 1759
Old 06-13-2011, 09:14 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,338
Like Greg said, a hinge stop.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
