DIY Steel Deck Frame? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By Nealtw
Old 06-18-2018, 11:48 PM   #1
Rewards Points: 43
DIY steel deck frame?
Is steel framing for a deck frame a reasonable DIY project for an experienced/avid home DIYer? If so, how would I go about doing the design and buying materials? It's not something Home Depot carries. ;-)
Reason: my house had a 40-year-old tiny deck (6' by 9') off the master bedroom to the back yard, about 2.5' above grade. It was rotted to pieces, I just tore it out last weekend.
I was going to rebuild it similarly, but a little larger (9' x 9'), but my wife and i discussed and we think we would enjoy a low deck, 6" above grade, better, with stairs down to it from the bedroom. But a wood framed deck only 6" high is going to rot fairly quickly, even in a dry environment (Los Angeles). Plus I really can't stand the smell of copper green -- I won't want to go in the backyard for six months if I have to CG treat cut PT lumber.
So I want to investigate the possibility of metal framing. But there isn't a lot of information on DIY construction of steel deck frames, so I don't know if it's something I can do myself.
(NOTE: we could just pour a patio but we'd really prefer the look of deck boards.)
IdahoEv is offline   Reply With Quote
Old 06-19-2018, 12:03 AM   #2
JUSTA MEMBER
Rewards Points: 414
Re: DIY steel deck frame?
It will need similar build designs as a wood deck, posts, rim joists, floor joists, stair rails, etc.
Do you have any welding experience?
I would use 2 inch square tubing, and weld up a frame with posts, joists, then screw the decking down to the 2 inch square tube rim joists.
Many industrial complexes build steel walkways all the time.
Materials available at any steel supply yard.
ED
de-nagorg is online now   Reply With Quote
Old 06-19-2018, 12:19 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 880
Send a message via Skype™ to AndyGump
If you plan on getting a permit for the new deck California will not recognize a non-engineered steel deck for that. A wood deck that is prescriptive designed (by code requirements) does not need engineering per se but still has to be designed per CRC deck code.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 06-19-2018, 03:32 AM   #4
retired framer
Rewards Points: 1,740
pour concrete.
Deck Staining Nightmare steven994 Painting 7 06-14-2017 05:56 AM
How to apply trim & moulding to Crowder Pocket Door Frame Steel Studs Toronto Carpentry 13 06-02-2015 07:29 PM
Loose stainless steel deck screws drtbk4ever Building & Construction 17 06-19-2012 10:26 AM
pre frame deck stairs? cbzdel Building & Construction 12 06-13-2012 11:01 PM
