Deadbolt Lock Adjustment? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-23-2014, 10:52 PM   #1
Rewards Points: 756
I have a door deadbolt lock in which when turning the deadbolt latch, the bolt won't extend all the way out because the hole in the door frame is not deep enough to allow it. How do I fix the opening to allow the deadbolt to fully extend? What tools do i need to fix this?
kennykenny is offline   Reply With Quote
Old 09-23-2014, 11:57 PM   #2
Rewards Points: 144
Hammer and chisel.Chisel the hole deeper or take the strike plate off and drill it out with a 1" bit and replace the plate.
mako1 is offline   Reply With Quote
Old 09-24-2014, 08:34 AM   #3
Rewards Points: 756
When you say drill out with a bit. How do you do that? What type of bit are you referring to? A spade bit? How does that work?
Old 09-24-2014, 08:43 AM   #4
Rewards Points: 144
Remove the strike plate and drill the jamb out deeper with a 1" bit.Spade bit will work.
Old 09-28-2014, 12:27 PM   #5
Rewards Points: 756
Is there anyway that the strikeplate won't come off? Is it sometimes behind the door trim that doesn't allow it to come off? Without the strike plate on, I can't get a spadebit into the hole to make it deeper.
Old 09-28-2014, 09:47 PM   #6
Rewards Points: 756
Here is a picture of my strike plate. How do I get it to come off? As you can see the hole is not very deep. Thanks for the assistance.
Old 09-28-2014, 09:52 PM   #7
Msradell's Avatar
Rewards Points: 976
By looking at your picture it looks like some wood in that frame was replaced including the fascia piece. Remove the screws and you may be able to get the strike plate to slide out from behind the other piece. You can't do that and just take a small drill bit, 1/4" or so and drill a bunch of holes and then use a hammer and chisel to clean it out. It's slower but would certainly work. You probably need to go about 1" deep are so. You can extend the deadbolt with the door open to measure the required depth exactly.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Antique mortise door lock repair (possibly deadbolt problem?) ohman Windows and Doors 14 08-18-2015 10:58 PM
Install a deadbolt lock french_guy General DIY Discussions 5 09-19-2014 10:55 PM
Installing Segal deadbolt lock traghel General DIY Discussions 2 01-03-2014 11:32 AM
Double Keyed Deadbolt Lock stuck in locked position hubbard Building & Construction 17 07-23-2012 03:28 PM
Mortise lock handle & deadbolt replacement creatrix Carpentry 4 06-01-2012 06:17 AM
