'Curvy' Fireplace Mantle - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-18-2017, 01:05 PM   #1
Rewards Points: 2
'Curvy' fireplace mantle
This is a unique fireplace to say the least! At first I wanted to remove all of the brick and create a more updated fireplace flush with the wall. My contractor talked me out of that so now the plan is the keep the fireplace intact with a whitewashed coating and some kind of crown moulding around the top.
First, would you add a crown moulding to create a cleaner look of a traditional mantle piece? If yes, do you have any suggestions or photos of a 'curvy' fireplace with an attached mantle?
Second, would you leave the top edge as is without adding the moulding?
Thanks for any advice provided!
'Curvy' fireplace mantle-img_7252.jpg   'Curvy' fireplace mantle-img_7253.jpg   'Curvy' fireplace mantle-img_7255.jpg
Cdvince is offline   Reply With Quote
Old 08-18-2017, 01:14 PM   #2
retired framer
Rewards Points: 1,372
Re: 'Curvy' fireplace mantle
It is very different, so no one will be able to tell you that what you do is wrong.
Old 08-18-2017, 01:19 PM   #3
retired painter
Rewards Points: 822
You could always cut a piece of crown molding and hold/set it in place to see if you think you'd like it. Neal is right, that is an unusual/different fireplace, I've never seen one like and I've painted 100's of homes with fireplaces.
mark sr is offline   Reply With Quote
Tags
fireplace finish , mantle , moulding , whitewash
Fireplace Mantle Amitabh Appliances 16 01-11-2014 04:11 PM
Making a Mantle for a Stone Fireplace. Two Knots Building & Construction 10 10-24-2013 06:53 PM
fireplace mantle MKGBC Remodeling 2 08-27-2010 12:38 AM
Fireplace Mantle need help with color and technique Staticman2 Interior Decorating 4 12-11-2008 03:05 PM
Question about wood mantle on stone fireplace Daggerhart Remodeling 2 06-15-2008 05:16 PM
