Covering Mirror With Brick Veneer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-05-2015, 12:56 PM   #1
Rewards Points: 34
My fireplace is finished out in mirrored glass. I want to refinish the outside in a stone veneer. Is there a way of installing over the mirror without removing it?
meppwc is offline   Reply With Quote
Old 01-05-2015, 01:00 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NO...remove the mirror.
XXX
Old 01-05-2015, 01:17 PM   #3
Rewards Points: 144
No.Had to ad more letters just to say no.
mako1 is offline   Reply With Quote
Old 01-05-2015, 09:39 PM   #4
Rewards Points: 1,796
That deserves a Sam Kinison "No, No, Nooooooo!!!"
ChuckF. is offline   Reply With Quote
Old 01-06-2015, 10:44 PM   #5
Rewards Points: 12
Oh, honey. No.
raen is offline   Reply With Quote
Old 01-07-2015, 12:57 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 9,510
Nooooooooooooooooooooooooooooooooooo
Old 01-07-2015, 08:34 AM   #7
Rewards Points: 358
Look your self in the mirror and ask... Do I really want to put all that work and money into it with substrate that could be problematic???
RegeSullivan is offline   Reply With Quote
Old 01-07-2015, 10:44 AM   #8
JOATMON
ddawg16's Avatar
I'm sure the OP will upon 'reflection', decide it's not a good idea.
Old 01-07-2015, 08:14 PM   #9
Rewards Points: 996
actually, it could be possible. firstt, you put framing, then cement board or whatever. then the veneer. basicly, like the mirror was never there, kinda
Fix'n it is offline   Reply With Quote
Old 01-07-2015, 08:17 PM   #10
Rewards Points: 582
remove all the mirror 1 st please....then proceed...thank you
Old 01-08-2015, 05:51 AM   #11
Rewards Points: 14
Scaring the next renovator could be fun.
carpdad is offline   Reply With Quote
What's covering my brick and how do I remove it? RubberSoul Concrete, Stone & Masonry 0 09-04-2012 08:11 AM
Stone Veneer Dry Stack over Brick Rotate Remodeling 7 01-05-2012 10:27 PM
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 09:46 AM
Anchors & Brick Veneer rjordan392 Building & Construction 9 06-04-2009 04:58 AM
Removing a brick veneer Bayou Woman Building & Construction 6 06-02-2009 05:21 PM
