Counter Top - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By KPDMinc
  • 2 Post By firehawkmph
  • 2 Post By Domo
Old 03-29-2019, 05:09 PM   #1
Rewards Points: 312
counter top
seam where the two pieces of quartz is coming apart. Best way to fix? I dont have the suction cup tool. And, Im not sure if the slab was glued to the substructure...
KPDMinc is offline   Reply With Quote
Old 03-29-2019, 05:16 PM   #2
retired framer
Rewards Points: 6,174
Re: counter top
There should be a reason for that, are the tops still level, has one cupboard moved for some reason, settling of the house. Anything that should be addressed so it doesn't repeat.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 03-29-2019, 05:48 PM   #3
Rewards Points: 312
Re: counter top
weeellll, what we believe happened is..... we have a (kind of large) puppy door under the overhang of the counter slab, had a few people over for adult beverages, and someone invented "THE PUPPY DOOR CHALLENGE" (in a nutshell, this is where the hoo-mans attempt to not get stuck while doing what the dogs do) in short, one rather large guest was coming through, and pulled herself up using the overhang of the counter top. soooo, In my opinon, our childish antics is what caused the seam to crack. But, I must say, we DO have fun at our parties.....
Nealtw likes this.
Old 03-29-2019, 06:05 PM   #4
firehawkmph's Avatar
Rewards Points: 2,550
Re: counter top
It's all over when the fat lady sings, or hoists herself up by the countertop.🤣
Mike Hawkins
Dave Sal and KPDMinc like this.
firehawkmph is offline   Reply With Quote
Old 03-29-2019, 06:16 PM   #5
retired framer
Re: counter top
Sounds like a wild time. So is the brackets under it that may to be wedged back up to level, I think they use coloured epoxy.
If you have access to both sides you could use a bar clamp to pull it together or make one with a 2x4 with a block on each end and use wedges to push it in.
Old 03-30-2019, 12:36 AM   #6
Contractor/Engineer
Rewards Points: 1,170
Re: counter top
Nealtw - I think we need the street address...
KPDMinc and Nealtw like this.
Domo is offline   Reply With Quote
kitchen counter tops crankbait09 Kitchen & Bath Remodeling 20 12-20-2016 06:28 PM
Would you butt or miter a butcher block counter top if... Big-Foot Kitchen & Bath Remodeling 15 12-13-2012 03:38 PM
Cutting Counter Top sleepysmurf Carpentry 3 08-14-2010 12:16 AM
Pop-up Kitchen Counter Receptacle paredown Electrical 11 03-12-2010 12:58 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 12:53 PM
