Connecting 2" Water Line Poly Pipe With Tool - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-16-2015, 07:31 PM   #1
Rewards Points: 8
connecting 2" water line poly pipe with tool
Every winter, my 600 feet of 2" poly pipe separates in several spots when it freezes. I would like to find a tool that would work to re-connect the separated lines that were joined together with barbed couplers. I would like some kind of tool that I could clamp in 2 spots on the 2" poly pipe that also would be connected to some leverage or racheting handle so I could reconnect the separated lines without major grunt or without a second person to help push the lines together. The tool would clamp the 2" line in 4 spots and then the rachets or handles to essentially pull the pipe sections together over the barbed coupler. Makes sense? The tool exists? Where? My sincere thanks.
Ron of Alaska
Renaldo7 is offline   Reply With Quote
Old 05-16-2015, 07:54 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 22,722
maybe you could make something like this. Try google 'pipe joint puller" for more examples.
http://propipesolutions.com/
http://www.hy-ram.co.uk/products/anc...t/pipe-puller/
The Following User Says Thank You to joed For This Useful Post:
gregzoll (05-18-2015)
Old 05-16-2015, 08:04 PM   #3
Rewards Points: 1,466
I suspect a comealong and a rope with a clove hitch knot each way from the joint and a clove hitch at the hooks would do what you be wanting to do.
If the rope slips on the slick pipe go for a chain or hit the pipe rope area with a little 80 grit sandpaper.
SeniorSitizen is offline   Reply With Quote
Old 05-16-2015, 08:19 PM   #4
Rewards Points: 2,262
Is it freezing because of water in it. There are proper ways to blow out the lines.
mae-ling is offline   Reply With Quote
Old 05-16-2015, 09:52 PM   #5
Rewards Points: 8
I like the look of the Eagle Claw pipe assembly tool, but as yet have not found it and whether it will work with 2" poly pipe.
Great lead.
My thanks!!!
Old 05-16-2015, 10:28 PM   #6
Super Moderator
joed's Avatar
I was also thinking one of these and couple chains. They jack in both directions, so you could open it up and pull together with it.
Old 05-16-2015, 10:36 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 574
I have used the pullers pictured. They are designed for 3" and larger pipe so you will probably have to design or adopt your own pipe clamps.
If your pipe is buried, how do you spread the ends enough to get a barbed coupling in and then pull the pipe together?
Have you considered pack joint/compression unions? I know they're not cheap- but neither is a tool that needs modifying.
http://www.fordmeterbox.com/products...w.php?catSec=J
Old 05-17-2015, 02:40 PM   #8
Rewards Points: 8
pipe puller-joiner
Does anyone think the pipe puller-joiner with chains would work with 2" poly pipe, poly pipe being slick and all?
Thanks,
Ron
Old 05-17-2015, 03:19 PM   #9
Super Moderator
joed's Avatar
If it started to slip I would just put a hose clamp on the pipe as a grip point.
Old 05-17-2015, 03:29 PM   #10
Rewards Points: 3,894
Do not use anything that will pull the pipe, this will loosen other joints...
ron45 is online now   Reply With Quote
Old 05-17-2015, 03:35 PM   #11
Rewards Points: 6,236
Having this happen every year makes me ask what would it take to fix it right.
Entering your general location can help with answering a lot of times
Old 05-17-2015, 03:56 PM   #12
Super Moderator
joed's Avatar
It would take properly draining the line so it won't freeze or replacing the line with one that has no joints. But there could be reasons he is not doing this.
Old 05-17-2015, 10:43 PM   #13
Rewards Points: 8
I try to get gravity feed on my water every year, as long as I can, so...until it freezes. Having a solid 600 foot line is hard to come buy and hard to manage and it might just split the line. Having it separate 3 or 4 places at 100 foot sections is therefore what I do. I like the idea of putting a stopper clamp to keep the would be chain from slipping on the slick poly pipe. I neglected to say that my Alaskan gravity water line is through some pretty woodsy and steep areas where I have the water catchment. I'm also trying to use a tool that is relatively light as I will be carrying it to the separated sections of pipe. I just now ordered some rugged clamps with eyelets and 2 chain tighteners to experiment with. Light and cheap, if it works. You people on here have been greatly helpful and I most appreciate it. If there was a reasonably cheap eagle claw joiner-separator that fit my 2" poly pipe I would certainly go that route. Again, thanks all.
Old 05-17-2015, 11:06 PM   #14
Super Moderator
joed's Avatar
You could probably construct based on the picture. Alaskans a pretty resourceful people.
Old 05-18-2015, 05:52 AM   #15
Rewards Points: 2,028
Ron of Alaska
As an electrician I must install expansion couplings when working with PVC conduit outside because it moves as the temperature changes. I just did a search for poly pipe expansion couplings and saw quite a few images of different types. Perhaps you should try installing them at each break.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Best option to plumb water softener line to water pipe jim20j Plumbing 5 02-19-2014 02:22 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
