Coleman Furnace Failure To Ignite - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-30-2014, 06:40 AM   #1
Rewards Points: 2
Coleman furnace failure to ignite
We had the furnace in our older mobile home replaced with a complicated Coleman. It worked OK for awhile. Then it would ignite, burn and blow for a couple of minutes then go out. The control box would flash once which meant failure to ignite according to the sticker. But it would ignite, then go out. We had it looked at by the sellers tech. He could not figure out the problem and every time he came out he changed another part until I doubt that there is a single original part left on that piece of....Of course the warranty expired before the problem was corrected. Any thoughts on what the problem might be and what to do about it?????
Richard from AZ is offline   Reply With Quote
Old 11-12-2014, 12:20 PM   #2
Rewards Points: 35
I've had similar issues with my furnace, although it's a completely different brand. It always ends up being a dirty flame sensor. I just clean it off with some steel wool/ sandpaper and it works fine for another 3-4 years. I'd check that first.
d189379 is offline   Reply With Quote
Coleman Mobile Home Gas Furnace Problems Cberkimer HVAC 13 11-16-2014 08:51 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 07:50 AM
Gas Furnace will not ignite after line purge - please help. philsoldat HVAC 4 05-13-2010 03:39 PM
Heil furnace won't ignite mjprel HVAC 24 10-23-2009 03:52 PM
