Change Electrical Switch Under Sink To Switch Outlet Combo. - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2016, 06:49 PM   #16
hkstroud's Avatar
Rewards Points: 6,376
Re: Change Electrical switch under sink to switch outlet combo.
PS
You could mount the air switch to the side of the cabinet, under the counter top. Make the counter top less cluttered.
hkstroud is offline   Reply With Quote
Old 08-08-2016, 07:03 PM   #17
hkstroud's Avatar
Originally Posted by nilanjan View Post
She's lazy she doesn't wanna take the time to fill soap dispenser bottle
Well, she does know that you fill the soap dispenser by lifting the pump mechanism out and pouring her Palmolive in from the top. You don't have to unscrew and remove the bottle to refill.
Old 08-08-2016, 07:35 PM   #18
Rewards Points: 118
That she does... She's seen me fill it before. I guess pouring soap into a bottle from the top can be a nuisance especially when you don't know how much is filled. If it overfilled then you gotta to clean it up.
I guess dishwAsher made it obsolete
Anyway I know she happy with dishwasher bcs when that broke she kept asking for dishwasher. It took Lowes 2 weeks for delivery.
nilanjan is offline   Reply With Quote
Old 08-08-2016, 07:40 PM   #19
hkstroud's Avatar
Did mean to be impertinent but I have known some people that didn't realize that you filled from top.
Old 09-16-2016, 04:14 PM   #20
CitadelBlue's Avatar
Rewards Points: 97
I ve heard that today's disposal electtical codes require that the unit be plugged in vs hardwired AND the switch be mounted under the sink and in the cabinet. Believe this is to prevent accidentally turning it on.
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is offline   Reply With Quote
Old 09-16-2016, 04:18 PM   #21
Rewards Points: 18
That is always the way i have done it in my house, but i only use batch feed disposers, the kind where you have to turn a handle on the strainer to turn the disposer on and off. I have always seen the continouos fed type with the switch on either the backsplash or a pushbutton on the countertop.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 09-16-2016, 05:01 PM   #22
Rewards Points: 97
Nephew has the switch under the sink in the cabinet.
Ken
Old 09-16-2016, 05:45 PM   #23
Rewards Points: 18
I should add that for the batch feed type, the purpose of the switch is a failsafe in case the strainer switch fails, which they are known to do after 10 or 15 years.
Old 09-16-2016, 09:50 PM   #24
Msradell's Avatar
Rewards Points: 980
That sounds really inconvenient! We have a switch on the backsplash which is quite convenient and much support to get to. I've never seen any place in the code that requires a switch under the cabinet. Does anybody have the code reference that requires them to be plugged in for new installations?
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 09-17-2016, 09:38 AM   #25
Rewards Points: 18
I am not sure why, but an electrician has told me that the switch for the continuous feed type is no longer allowed to be on the backsplash wall. That makes no sense to me, and I am not sure if he is correct, but he has been an electrician for a little over 20 years. I believe that countertop switch is still legal. Can anyone here shed any light on this?
Troubleshoot a 4-way switch circuit: instructions for a 2-year-old pete0403 Electrical 22 09-28-2019 10:54 PM
can't get new combo switch outlet to work woodcrazy Electrical 6 01-15-2013 09:52 PM
How to rewire outlet controlled by light switch? BuckyGunts Electrical 30 04-20-2012 03:18 PM
electrical outlet switch controlled jluce Electrical 1 08-25-2011 01:56 PM
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 06:02 AM
