Is A Cement Sealer Necessary? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-06-2016, 08:47 AM   #1
Rewards Points: 194
Is a cement sealer necessary?
Just had some cement work done on front and back porch steps, sides of porch, cracks on front porch floor, foundation, etc.). Results were very messy as cement was all over the aluminum siding, just slathered on crack (not smoothed out at edges), and cement was applied in a stucco fashion to the riser of steps and other areas - which means the cement was just slopped on any which way. So, I bought a rubbing stone and smoothed out some areas.
Does the smoothed out areas now need to be sealed or painted? If so, what's a good sealer? The initial job was not sealed.
Live in Boston, MA
Jacke is offline   Reply With Quote
Old 09-06-2016, 04:15 PM   #2
Rewards Points: 18,988
Re: Is a cement sealer necessary?
How about some pictures so we can see what your seeing?
Jacke (09-07-2016)
Old 09-07-2016, 09:38 AM   #3
Rewards Points: 194
Not sure if this is how it's suppose to be done but I have uploaded pictures of cement work to my album. Hoping you can click on it and see. Thanks
Sloping Cement Floor guerin_matt Concrete, Stone & Masonry 2 06-23-2014 06:02 PM
Sloping Cement Floor guerin_matt Flooring 1 06-23-2014 11:47 AM
question about hanging cement board in shower pillowshack Drywall & Plaster 0 01-12-2013 06:55 PM
can i mix asphalt sealer and cement ???? jake trudell Building & Construction 1 07-27-2010 02:08 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 08:32 AM
