Cedar Wood Rail Damaged On Picket Fence - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 09-05-2018, 07:21 PM   #1
Rewards Points: 118
Cedar wood rail damaged on picket fence
Hi All
Please see pictures. This is from the back end section on my fence. The pickets and rails were just power washed and sanded for staining.
Is damage from rot or insects? I thought cedar does not rot. Could it be from wood eating insects like termites??? I did see insects crawling in and out of the wood like they have a nest in there.
Any thing i can use to prevent insect damage?
Thanks.
nilanjan is offline   Reply With Quote
Old 09-05-2018, 08:21 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,084
Re: Cedar wood rail damaged on picket fence
Looks like rot to me.
Cedar does rot. It just takes a bit longer than other species. Once it starts to rot insects will move in.
Msradell likes this.
Old 09-06-2018, 05:52 AM   #3
Rewards Points: 492
Also not all cedar are same. Search but your fence may be cedar but not the resistant kind. New growth cedar, I heard, is also not as resistant as old growth? Rails are also rotting at the end grain, common problem, as well as butt jointed which doesn't dry well. Also does not look 2x.
If you are not concerned about how it looks, you don't have to replace the whole fence. You can put a new rail under the existing and fasten.
carpdad is offline   Reply With Quote
Old 09-06-2018, 07:14 AM   #4
retired painter
Rewards Points: 1,384
While cedar is naturally decay/insect resistant it isn't bullet proof. When I lived in fla I got a deal on some cedar 4x4 posts so on my fence I used both cedar and PT pine posts. I lived there 13 yrs during which time I had to replace every cedar post, the PT posts held up fine. I'd replace your rails with pressure treated where needed.
Where your rail rotted has several things going against it. Joints will always absorb moisture and being behind a picket it will take longer to dry along with being a collection point for leaves and such which also hold water. Unpainted cedar will absorb moisture quicker than unpainted PT.
mark sr is online now   Reply With Quote
New Western Red Cedar fence; when to stain, what to use lazzlazz Painting 11 08-31-2017 10:40 PM
Wood fence Paint Options, head is spinning!!! Slater1 Painting 16 03-30-2017 09:08 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
How to pre-treat wood for fence? nebben Landscaping & Lawn Care 3 04-29-2007 10:14 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
