Caulking Or Adhesive Around Tub Has Mold. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-07-2013, 01:20 PM   #1
rkj
Rewards Points: 79
Caulking or adhesive around tub has mold.
I don't know if its caulking or adhesive, but its turning black. I tried to use a toothbrush, but I think its underneath the caulking. Few pics:
http://i.imgur.com/SsgVyGo.jpg
http://i.imgur.com/aDsmUVd.jpg
I don't know if its mold or adhesive, but I just feel like putting white caulking on top of it. I don't know how to go about removing it without scratching the tub.
The tub is a fiberglass surround, and I think it cames in two pieces which join together. What could I try?
rkj is offline   Reply With Quote
Old 12-07-2013, 01:58 PM   #2
Mad Scientist
I can't make much out in those pictures, but generally; if the caulking is ugly, replace it. If you caulk over it, the staining will show through. Get a caulking removal tool, it's got a metal "loop" sort of blade on it that digs under the bead of caulking and peels it away. A small putty knife helps for the difficult spots. You want to try to remove as much of it as you can, and run a new bead of white silicone caulk. If you're careful, you won't scratch anything. Plastic-bladed scrapers have less of a chance of leaving marks on the tub.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
rkj (12-07-2013)
Old 12-07-2013, 04:34 PM   #3
Rewards Points: 18,376
Looks like someone made a real mess of that caulking.
It only needed to fill the gap, not be all over the enclosure and tub.
Old 12-07-2013, 10:29 PM   #4
rkj
Rewards Points: 79
ok, the good thing is that the existing "caulking" isn't too deep but I was still not sure if i should remove it aggressively. Will try though....What size bead should I smooth it out to with the silicone? 1/4"?
Old 12-10-2013, 03:50 PM   #5
Rewards Points: 14
I would also recommend that you go with a good quality caulk that resists mold and mildew. The extra couple bucks spent are well worth the hassle of having to remove and replace it again.
nvrfinished is offline   Reply With Quote
Old 12-10-2013, 09:34 PM   #6
Rewards Points: 9,368
Looks clear, so its likely silicone. You may have difficulty with adhesion on a surface with silicone film on it.
All caulking is not created equal. The stuff labeled "Kitchen and Bath" has a mildew-cide in it to discourage mold.
SPS-1 is offline   Reply With Quote
Mold spore counts and mold remediation Peter Cumming General DIY Discussions 4 03-30-2012 07:26 AM
mold on subfllor jigijunk Flooring 11 02-20-2012 02:14 PM
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 08:52 PM
Mold in my brand new house ! dumbguy5689 General DIY Discussions 3 09-07-2010 02:26 AM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
