Buying A Toilet - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 03-20-2020, 08:18 PM   #16
Rewards Points: 3,906
Re: Buying a toilet
In some cities in the US, you can just use the sidewalk
Originally Posted by Bud9051
Of course they had already been around for over 200 million years but on a planet that could go for billions of years maybe captain Kirk would have had big teeth and a long tail.
That Guy is offline   Reply With Quote
Old 03-20-2020, 08:21 PM   #17
Missouri Bound's Avatar
Rewards Points: 2,732
Re: Buying a toilet
Ahem......I believe those are sanctuary cities......not to be confused with sanitary cities.
Msradell, Dave Sal and That Guy like this.
Do you want it your way or the right way?
Old 03-21-2020, 05:04 PM   #18
Rewards Points: 1,380
Re: Buying a toilet
With the two part there is a single rubber seal that might after 30 years need to be replaced. Other than that they are the same as the one-piece toilets. Read the reviews online at places like Home Depot and Lowe's as the ones stocked in the stores are not the best available from either of these companies.
ďIn a world of climate change, the rich will find the world to be more polluted, more uncomfortable, colorless, and a bleaker world. The poor will dieĒ. Kirk R. Smith
Calson is online now   Reply With Quote
Old 03-22-2020, 02:26 AM   #19
Rewards Points: 5,142
Re: Buying a toilet
WOW!
When it comes to doing our daily constitution so much emphasis has been put on the toilet.
I guess we have come a long way from the concept of digging a hole and then covering it up.
ron45 is offline   Reply With Quote
Old 03-22-2020, 08:28 AM   #20
Rewards Points: 4,316
Re: Buying a toilet
I have the Champion.
Well, actually I’ve had 2 in this house. The first Champion, installed by me, cracked in half in the middle of the night, all by itself and untouched.
AS happily sent me a brand new one free of charge, wax ring included. This one has not cracked in half.
I’d buy another.
roughneck is online now   Reply With Quote
Old 03-22-2020, 12:51 PM   #21
Oso954's Avatar
Rewards Points: 1,264
Re: Buying a toilet
Normal flush for a modern toilet is about 1.6 gallons.
Depends where you are. California has been 1.28 gpf for residential since 2016. Texas is also. Iíve heard of other states but haven't been tracking them.
Oso954 is online now   Reply With Quote
Old 03-25-2020, 10:03 AM   #22
Rewards Points: 260
Re: Buying a toilet
I'm partial to TOTO toilets after having installed 4 of them in two different houses I've lived in. They've always replaced some other brand that had one problem after the other (clogged, or didn't flush well, or wasted water, etc). Every single one of them has worked flawlessly, in one case for 10 years without needing even a flapper valve replacement. The other three were still going strong when I moved out of those houses. Not a single clog, good flush every single time, and only 1.3 gallons per flush.
I'd never install any other brand. TOTO does make 1 piece toilets, but I prefer 2 piece because each piece is much lighter and easier for the DIYer to install. I also don't much like the tall ADA versions as I find them uncomfortable, but everyone has their own preferences.
Finally, with regard to soft-close seats - these are amazing and when you replace a toilet, you can install whatever seat you like. Definitely consider a soft close. There are also detachable ones that you don't have to unscrew in order to clean the area where the seat attachment meets to bowl.
snic is offline   Reply With Quote
Old 03-25-2020, 10:49 AM   #23
Rewards Points: 126
Re: Buying a toilet
I installed 2 Toto Drakes elongated (2 piece per set) and couldn't be happier. I watched all kinds of videos from folks trying to stop them up and not a single fail. I also bought the extended height bowls (ADA) as these are long term purchases and with getting older a taller bowl is better. I chose 1.6 gallons per flush which was an improvement over the 3.0 GPF that I put in the house when I built it in 1990.
Highlander86 is offline   Reply With Quote
The Following User Says Thank You to Highlander86 For This Useful Post:
gma2rjc (03-25-2020)
Old 03-25-2020, 01:43 PM   #24
Rewards Points: 104
Re: Buying a toilet
I have had both AS and Kohler. My preference is for AS.
The bowls in our current condo were low and small, round. They were replaced immediately.
manatee is online now   Reply With Quote
Old 03-25-2020, 06:59 PM   #25
Pro Answers
Rewards Points: 232
Re: Buying a toilet
Kohler Highline over the Cinnaman.
I would stay away from Amer. std stuff unless your working with commerical products and Commercial Amer. std vendors. Amer std is a huge company that as bought out many small companies yet there quality control had gone down the Sh$%itter due to the brands they now label with and the short cuts they take. seems the way of capitalistic USA ford, GM, Whirpool, Sherman williams, Carrier I could go on and on and on.
Its called comfort height - which can comply with ADA. Beware that many manufacture market comfort height differently so LOOK AT THE ACTUAL height measurements floor to rim. You'll thank yourself when you have that knee or hip surgery.
Most Americans dont know shi$%T and I mean that in that they dont know how to defecate properly- too much strain on the large intestine, IBS, Crones, hemorrhoids. Google Squatty Pottyís . That said comfort height will get things moving in the correct direction.
* if your doing the toilet install yourself go with the 2 piece theres also some big adv vs 1 piece.
jmig7 is offline   Reply With Quote
Old 03-26-2020, 05:14 AM   #26
Naildriver
chandler48's Avatar
Rewards Points: 1,830
Re: Buying a toilet
I hate to disagree with you on this, but having your knees higher than your waist is the best position. One way to help in this is to build a short stool (8" or so) that you can drag under your feet while seated to raise your legs if you have a comfort height toilet.
After 2 knee replacements, I agree that the comfort height is a God send.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-26-2020, 07:03 AM   #27
Rewards Points: 2,712
Re: Buying a toilet
Squatty Potty FTW.
huesmann is offline   Reply With Quote
Old 03-26-2020, 07:48 AM   #28
Rewards Points: 1,254
Re: Buying a toilet
I have 2 Kohler Devonshire an like the look of the tank lid.
But they have a rubber ring flapper gasket an I donít think its as easy to replace as the solid flapper gaskets in older toilets. Maybe they all have rings now I donít know.
Daughter put 3 straight side toilets in her house so she didnít have to dust the sides. We havenít figured how to tighten the seats on those an havenít looked it u up yet.
Startingover is online now   Reply With Quote
Old 03-26-2020, 08:00 AM   #29
Rewards Points: 166
Sorry for late post. Here’s a few pics
Buying a toilet-c8f7168e-b290-4484-8214-3b605d75b20a_1585227496752.jpg   Buying a toilet-d5e92d5c-6608-4dec-a823-59d52c2a6a23_1585227596024.jpg
hellothere123 is offline   Reply With Quote
Old 03-26-2020, 08:28 AM   #30
Rewards Points: 4,242
Re: Buying a toilet
The old style lower height comes closer to NOT needing the - Squatty Potty - but after installing the taller elongated i'll never recommend the lo and round. American Standard for us.
