Broken Metal Futon Frame Tube Rod - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-08-2015, 09:05 PM
Rewards Points: 8
Broken metal futon frame tube rod
A main support tube rod in my metal futon frame broke. The rod is on the bottom and it runs along the length of the futon. When sitting, your butt would be by that rod. The rod broke in the middle of the futon.
I'm not sure if the rod was welded initially or not, or how it was connected, but it does seem to be formed of two separate rods initially.
I cannot post images, but if it will let me post them in my next post, I will do that.
Do you know how I can go about fixing this?
Cibirochka is offline
Old 03-08-2015, 09:29 PM
Msradell's Avatar
Rewards Points: 976
Lots of times tubing is very difficult to weld because of how thin the walls are. It may be easier to find a piece of pipe that just barely fits inside of the existing tubing. Get a long piece so that is extends a good ways past the break on both sides. Slide it inside, drill some holes through the tubing and the pipe and insert bolts or rivets.
Pictures would certainly help.
Written using Dragon Naturally Speaking
Msradell is offline
The Following User Says Thank You to Msradell For This Useful Post:
Cibirochka (03-08-2015)
Old 03-08-2015, 10:13 PM
Rewards Points: 8
It still tells me I need a post to post links, which is the only way I see of showing the photos. I will try with the piece of pipe though, thank you.
Old 03-08-2015, 10:16 PM
Rewards Points: 8
Oh, I finally figured out how the attachments work.
This is the closeup:
Farther away:
Old 03-08-2015, 10:22 PM
Mad Scientist
Ah, there's supposed to be a small tube that fits inside the two tubes at that point, and I think a couple screws, one on each side of the joint, to hold it together.
McSteve is offline
Old 03-08-2015, 10:40 PM
Rewards Points: 8
I don't see any holes for screws in these two tubes, but looking at the other rod, it does seem like there's something inside, thanks.
Broken slip joint nut (metal drain pipe) dgpsf Plumbing 5 05-30-2015 09:28 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Broken metal swing question with pics. Jim F General DIY Discussions 5 09-03-2012 02:52 PM
How to fix a broken frame corner of a slide window George II Windows and Doors 1 05-07-2011 03:04 PM
Advicce on broken joint on wooden frame of chair markhod Carpentry 2 08-11-2007 09:48 PM
