Thread Tools | Display Modes |
#1 |
Rewards Points: 166
![]() Boarding up old windows?
This is a rather strange question but here goes. I am replacing the old windows in my home next summer. I was thinking of closing the windows up completely with plywood in both bedrooms. We have loud neighbours and these windows aren't visible from the street. I was thinking the plywood would help with the noise in the mornings and that they would help with heat loss over winter. I live in canada. I don't have a need to open the windows at all. Strange idea but hoping it makes sense until I replace the windows next year. Will it work?
Sponsored Links | |||
Advertisement |
#2 |
![]() Join Date: Mar 2010
Rewards Points: 72
You may find a need real quick if there's a Fire.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom
The Following User Says Thank You to kwikfishron For This Useful Post: |
gregzoll (09-20-2014)
Advertisement |
#3 |
Rewards Points: 2,536
It's against the fire regulations while occupied. You need alternate fire exits in the bedrooms.... and those are usually the windows.
Advertisement |
#4 |
Exterior Construction
![]() Join Date: Aug 2011
Rewards Points: 6,764
+1
You need to check with code. Heavy drapes will help with the sound and energy loss in the meantime. |
#5 |
Rewards Points: 996
how about boards on the inside ? with some kind of quick release.
#6 |
Rewards Points: 82
Interior shutters.
#7 |
Rigid insulation on interior side of window. I do this in winter to save on heating costs, but it might be good for sound insulation as well. I cut to exactly fit, that is, they are simply pushed placed in position...no nails/screws/other is necessary
#8 |
Jello Wrangler
Rewards Points: 539
Depends on your local code but you most likely can not close off those windows if it is still intended to be a bedroom. Some codes require it only up to a certain level. Typically at or above the fourth floor.
#9 |
Rewards Points: 6,236
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Leaking Milgard vinyl windows (occasionally) | lazzlazz | Windows and Doors | 14 | 08-08-2015 03:40 PM |
69 year young lady struggling with windows | robaire | Windows and Doors | 6 | 01-18-2012 08:01 AM |
Windows? | Erickp40 | Windows and Doors | 5 | 11-17-2011 11:53 AM |
Any restitution for VERY late windows? | msbriggs | Building & Construction | 21 | 10-05-2010 07:25 AM |
