Bifold Door Bottom Pin Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 3 Post By Nealtw
  • 2 Post By 123pugsy
  • 1 Post By Brian Famous
Old 10-05-2019, 12:18 AM   #1
Rewards Points: 46
Bifold door bottom pin repair
Have a large bifold closet in a house we moved into 5 days ago, door fell off the track. Bottom pin was pushed flush to the bottom of the door. Unscrewed the pin about 8 threads, and it almost works, but it's super wobbly (you can see how crooked it is in the picture) and with just a little finagling I can easily get the upper guide to fall out of the tracks.
I'm thinking the bottom pin needs a new better opening to screw into, is there a way to refill and retap this that'll hold up?
Sent from my Pixel 3 XL using Tapatalk
skiflyer is offline   Reply With Quote
Old 10-05-2019, 01:24 AM   #2
retired framer
Rewards Points: 6,028
Re: Bifold door bottom pin repair
This is about the quickest and easiest fix
https://www.amazon.com/Closet-Savers.../dp/B01GU90892
Do not use flat bottom gables with scissor trusses.
Old 10-05-2019, 06:53 AM   #3
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,528
Get some carpenter's glue, white/yellow, and a piece of dowel.
Be generous with glue. Cut a piece of dowel a bit longer than the hole. Glue it in. Wait 24 hours. Sand part sticking out flush with door bottom and good as new to reinstall the pin.
skiflyer and mark sr like this.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
Old 10-05-2019, 06:56 AM   #4
123pugsy's Avatar
You can also drill the hole a bit bigger to suit the dowel for a better result.
Old 10-06-2019, 09:14 AM   #5
Correct me if i am wrong, but even if you dowel the hole and redrill, isn't your pin still going to be too short unless you have it unscrewed a fair amount? Thereby allowing the wobble to return?
If so, you may just want to consider also adding a 1/4" block to the bottom corner of the door after doweling. It will allow more of the pin to remain screwed into the door and should correct the issue that seems to have initially caused the problem.
Nealtw likes this.
Brian Famous is offline   Reply With Quote
