Best Anchor For Plaster Lath - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-17-2015, 09:21 AM   #1
Rewards Points: 9,368
I need to mount a hanger rod in a closet. Walls are old plaster lath. I was planning to mount a 1 x 2 about 12" long on both walls, perhaps 3 or 4 screws each, and then mount the rod to the 1x2's. What is the best anchor type ?
SPS-1 is offline   Reply With Quote
Old 10-17-2015, 09:31 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,416
If you aren't carrying much weight, grabbing the wood behind will normally provide enough holding power.
These style anchors have always worked well for me in hollow wall designs.
Old 10-17-2015, 10:05 AM   #3
Rewards Points: 18,376
As in a rod that's going to support garments?
If so your going to need to find the studs.
I've seen those molly bolts used and it just ripped a huge hole out of the plaster when it came down.
Hard to find studs in a plaster wall, couple of different ways to do it.
A magnetic stud finder should be able to find the nails in the lath.
Look for the nails in the baseboard.
As a last resort I'd us large butterfly bolts.
Colbyt (10-17-2015)
Old 10-17-2015, 08:59 PM   #4
Rewards Points: 1,900
Make the board wider, maybe 1x6 or so, all the way from back to front of the closet, then after you have the rod mounted you can throw a shelf on top.
ChuckF. is offline   Reply With Quote
Moldy Lath Strip Bundles Chris Sweeney General DIY Discussions 2 06-28-2013 11:24 AM
mildew on wood lath L Gallagher General DIY Discussions 7 12-20-2009 12:11 PM
Metal Lath FUJIMO Building & Construction 6 12-17-2009 08:35 PM
fixing old wiring in 40's bulit home with rock lath pacifier1er Electrical 2 12-15-2009 07:31 PM
