Basement Water Leakage From I Beam - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Yodaman
  • 1 Post By 3onthetree
Old 10-01-2019, 04:23 PM   #1
Rewards Points: 2
Basement water leakage from I beam
Hey folks, new to the forum. Have a question about the water leakage in my basement around the I beam. Is it something I fix myself? Attaching a picture for more accurate spot.
Any help would be really appreciated.
Basement water leakage from I beam-31ce2bf1-8469-4a04-b8f8-4b177ba683f2_1569961416118.jpeg   Basement water leakage from I beam-26691b31-fd98-4b0f-88d4-fc4d7a5f501a_1569961430134.jpeg
r00724 is offline   Reply With Quote
Old 10-01-2019, 04:40 PM   #2
retired framer
Rewards Points: 4,588
Re: Basement water leakage from I beam
That will need some waterproofing from the outside, can you dig it up and wash the wall so can see what you have outside.
Do not use flat bottom gables with scissor trusses.
Old 10-01-2019, 04:48 PM   #3
Rewards Points: 2
I guess I can but it'll not be easy...lol. Anyway to do it from inside? Also, how much am I looking at cost wise if I get this done through a contractor?
Old 10-01-2019, 04:54 PM   #4
retired framer
It has to be done on the outside. Mostly it is something to be painted on the outside and give the water a path away from the house.
Old 10-01-2019, 06:37 PM   #5
Property Mgt/Maint
Rewards Points: 7,392
Show us a picture of the that side of the house from the outside.
Nealtw likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
Old 10-01-2019, 09:41 PM   #6
Msradell's Avatar
Rewards Points: 952
What part of the country do you live in? That will have a major impact on the price to have the work done for you.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 10-02-2019, 12:18 AM   #7
Rewards Points: 492
Did you also check the plumbing? Fairly large drain pipes. Toilet above? Going up to a vent? Both may leak but not obvious from outside. The beam pocket was cut and packed with cement. That is a cold joint which can leak easily if water is coming in from outside.
carpdad is offline   Reply With Quote
Old 10-02-2019, 02:35 AM   #8
Hammered Thumb
Rewards Points: 742
That should only be about 12 inches below grade? Eight swipes with a shovel?
That seems like a lot of water through a crack at a beam pocket (repair in wall), is there some pooling outside or a slab sloped towards wall?
Nealtw likes this.
3onthetree is offline   Reply With Quote
Old 10-02-2019, 08:29 AM   #9
Rewards Points: 1,784
It looks to me like there was prior leakage, then somebody tried to patch with grout or similar around the beam, where it started leaking again.
huesmann is offline   Reply With Quote
Old 10-02-2019, 11:03 PM   #10
Concrete & Masonry
Rewards Points: 458
Agreed, there's something strange going on outside, like either standing water against the house, or a patio that's pitched to the house, etc....
jomama45 is offline   Reply With Quote
