Attic Fan Motor Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-13-2019, 05:29 AM   #1
Rewards Points: 2
Unhappy
Attic fan motor replacement
The motor in our roof mount attic fan went out. The old motor is Clark United 120V 60HZ and 1.7 amp. Apparently Clark United is no longer in business and I can not find any replacement motors with the 1.7 amps! Any advice is appreciated. Thanks
Bhouse80 is offline   Reply With Quote
Old 09-13-2019, 06:53 AM   #2
retired framer
Rewards Points: 1,584
Re: Attic fan motor replacement
Can you post a picture of the one you have.
Do not use flat bottom gables with scissor trusses.
Old 09-13-2019, 07:32 AM   #3
Rewards Points: 892
Might be easier to just replace the entire unit.
huesmann is offline   Reply With Quote
Old 09-13-2019, 09:09 PM   #4
Rewards Points: 534
I find itís cheaper to buy the whole gable fans. Motor is the same at least in the ones Iíve seen and you get a new blade and thermostat if necessary. Itís a little tricky to get the fan blade loose from the attic side but Iíve done it a bunch of times and it works well.
BayouRunner is offline   Reply With Quote
Tags
attic fan
