DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   General DIY Discussions (https://www.diychatroom.com/f2/)
-   -   Attaching metal to plastic (https://www.diychatroom.com/f2/attaching-metal-plastic-667663/)
jasonfodor 09-12-2019 05:27 PM
So, I'm off to college and my little brother is bummed out I'm not there to use our baseball machine with him.
I'm thinking of setting up an automatically feeder for him as a weekend project when I go home to visit in a few weeks.
Here's the pitching machine we have from SpinBall. Essentially you put a ball into the ball feeder tube chute (red arrow) and the pitching machine spits the ball out with it's spinning wheels.
https://i.redd.it/4tg0fxow7ql31.png
Now, the automatic feeder essentially stores baseballs and releases one every 10 seconds or so into the pitching machine for you, eliminating the need to have someone feed the machine baseballs.
Here is a makeshift feeder someone made (not sure what they used as the motor, and not sure how it attaches to the machine).
https://i.redd.it/i683fprv8ql31.jpg
I was able to find two automatic feeders online from Heater Sports for only $60, which is certainly affordable and probably a better route than making my own feeder.
https://i.redd.it/enetgceq9ql31.png
The two poles on the automatic feeder attaches to their two holes on their pitching machine, as shown below.
https://i.redd.it/4gaen5y2aql31.png
Heater Pitching Machine
But my pitching machine doesn't have two holes for their automatic feeder, so now the million dollar question is, how do I attach their automatic feeder onto my pitching machine?
(1) My ball chute (where baseballs go in - red arrow on the first picture and the two images below) is actually removable. It has a bracket it attaches to. My preference is to some how use Heater Sports feeder and some sort of flexable computer monitor arm and attaching it to my bracket of my pitching machine then I can easily use flexible tubing to connect the feeder to my ball chute. But the hard part is how do I attach the automatic feeder to a computer monitor arm/holder.
(2) Probably the easiest method would be to attach the automatic feeder directly to my ball chute. It's made of hard plastic and should hold up the weight of the feeder and baseballs. But I have no idea how I'd attach the automatic feeder to my ball chute.
(3) Third method would be to some how get the automatic feeder on it's separate tripod stand (similar to what SpinBall's automatic feeder is) then I could easily use flexible tubing to connect it to my pitching machine. Again, the part that needs figuring out is how to attach the automatic feeder onto a tripod.
Have basic typical tools most households have (drill, screwdriver, wrench etc.), don't have access to or know how to weld.
https://i.redd.it/wnanqsbzbql31.png
my insert ball chute
https://i.redd.it/po7lycg1cql31.png
Nealtw 09-13-2019 07:36 AM
Re: Attaching metal to plastic
So you want something that would work with bluetooth,
https://create.arduino.cc/projecthub...arduino-bc2035
https://hackster.imgix.net/uploads/a...&h=510&fit=max
huesmann 09-13-2019 07:46 AM
I mean, if it was me, I'd just duct tape the ball "magazine" to the feed tube and support the magazine with a stick (or if I was feeling fancy, a camera tripod or the like).
SPS-1 09-13-2019 08:10 AM
1 Attachment(s)
You could make a bracket out of aluminum angle to attach the feeder to the pitching machine.
you would also need to make or buy a support for the other end of the feeder. I would probably just make something out of 1x2's (wood), with some vertical adjustment.
Yodaman 09-13-2019 08:21 AM
What is the size of the base balls? You might be able to do something with PVC pipe. 2" is probably to small, but 3" may seem excessively large. But if you could find a ideal size, it could be connected with a rubber coupling.
jasonfodor 09-19-2019 07:42 AM
2 Attachment(s)
That's not a bad idea, but how would i attach the feeder to the tripod?
Honestly if i Knew how to get the feeder on a tripod, it'd just be easier to connect the feeder to the ball chute with flexible hosing.
They do sell the back half of the u-brace off one of their pitching machines separately for $50. It has the two holes on top for their feeder. Might go down that route, but again, I need to figure out how to get this back half of the U-brace on a tripod by itself. Then it's just flexible hosing to run the ball to my pitching machine
-OR-
cut off the half U (bottom part) on the u-brace, so it's just the round pipe and feeder holder (top part) and attach that directly to my pitching machine. Again, the question is how would I attach it to my machine
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
