Asbestos In Lath & Plaster? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 06:28 PM   #1
Asbestos in Lath & Plaster?
Hi,
I asked this question before for a different wall that i am removing And it turned out to be two layers of gypsum. I'm removing an adjacent wall as well and started opening up a few sections. I got to one lathe and plaster section and noticed in the plaster these brown hairs (horse hair?).
I plan on getting an actual respirator instead of this face mask. Maybe a shield as well.
But can some take a look at this picture and let me know what I'm looking at? I did a little research and read that people put hairs in plaster to keep it from crack and provide stiffness.
Just want to make sure that it's not asbestos. Any thoughts?
Thanks.
management is offline   Reply With Quote
Old 10-14-2011, 07:22 PM   #2
Retired Moderator
Rewards Points: 7,174
Not asbestos--various fibers were used in plaster --horse hair--linen (flax)--hemp and what ever was available locally.----
Old 10-14-2011, 07:25 PM   #3
Ok great. So I'm free to proceed with respirators, etc?
Old 10-14-2011, 07:36 PM   #4
Retired Moderator
Yes,you are---Lead paint may be present so plastic off the area---use strong fans in the windows to blow the dust out and create a negative pressure (Helps keep the dust out of the house)
Shower well after work and keep kids out of the house while working.
And have fun!---Mike---
Old 10-15-2011, 03:16 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 34
As a home owner you can do this. As a contractor, NOT
Old 10-15-2011, 03:48 AM   #6
What's the problem for a contractor? I'm not one btw I'm the homeowner.
Old 10-15-2011, 04:58 AM   #7
Retired Moderator
New government regulations---RRP---Joe Sheridan has a blog on it ----Contractors need to get certified in lead abatement--then follow strict rules when working in or on a house built before 1978.
This adds approximately $600 to a fairly simple demolition job.(supplies --time--testing)
Old 10-15-2011, 05:17 AM   #8
Man I love this forum. Thank you.
Lastly, behind the wall there is some metal lathe running vertical instead of horizontal like wooden lathe. Seems like a door use to be there. What's an easy way to remove metal lathe?
Old 10-15-2011, 05:38 AM   #9
Retired Moderator
It's just nailed on--knock it loose with a hammer--
How old is the house??---those studs make me think you have a very old structure there.
Old 10-15-2011, 06:14 AM   #10
It was built in 1880. Pretty old house.
My first house and I'm renovating it. Learning a lot as I go. :-)
That wall you see is coming down.
Old 10-15-2011, 06:31 AM   #11
Retired Moderator
Those old places are a challenge to work on----the framing methods were different back then---
I love working on antique houses but seldom get the chance----
I'm helping a young couple get a 100 + years old house ready to move into---
They had a setback when I pointed out the wiring was to dangerous to live with---so their 'new bathroom' money went to 'complete new electric'---
At least I can sleep , knowing that the house won't burn down for bad wiring.
Neat little cottage----All the old trims remain---nice--we salvaged the original floors (home owner hand belt sanded the two rooms using my 4" sander)---Looks nice---
Keep the pictures coming---Mike----
Old 10-17-2011, 08:07 AM   #12
Mike - My house is built exactly the same way. They used real 2x4 oak studs and 1" thick oak boards as sheathing around the house. The studs were twisted as a screw and i had to sister 2x4 pine studs next to them so I could hang drywall after i gutted the room.
I only have 2 out of 4 rooms done. Not looking forward to the next two. Good luck!
ironman70 is offline   Reply With Quote
The Following User Says Thank You to ironman70 For This Useful Post:
oh'mike (10-17-2011)
Question about lath and plaster walls mandieshawn Building & Construction 9 05-18-2011 08:43 PM
Venetian Plaster FYI Plaster Ayn Painting 10 06-30-2010 11:26 PM
Installing baseboards on lath & plaster B Scott Remodeling 6 07-05-2008 09:29 PM
Fishing through plaster and lath walls?? slatergrl Electrical 7 02-05-2008 08:29 AM
Asbestos in plaster? Erebus Remodeling 1 02-15-2007 08:13 AM
