Arbor Using Saddle Posts In Concrete - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Guap0_
  • 1 Post By Gregsoldtruck79
  • 1 Post By romeojk27
Old 09-07-2018, 04:50 PM   #1
Rewards Points: 4
Arbor using saddle posts in concrete
I currently have 3' concrete pilings with saddle posts set. I want to set a 6x6x10 post in them and run a line of four posts to create an arbor. 1. Is the one carriage bolt that holds the post in the saddle strong enough to prevent sway?
2. Can I cantilever my decorative stuff at the top ie. 1' in one direction and 3' in the other?
Thanks in advance.
Sarahpfau is offline   Reply With Quote
Old 09-07-2018, 04:55 PM   #2
retired framer
Rewards Points: 4,588
Re: Arbor using saddle posts in concrete
Thanks in advance.
3" piling sounds too small, I doubt a saddle will hold anything stiff.
Post a photo of what you are doing.
Old 09-07-2018, 04:58 PM   #3
Guapo
Rewards Points: 11,950
What is the decorative stuff? Will it connect one post to another?
Nealtw likes this.
Guap0_ is offline   Reply With Quote
Old 09-07-2018, 11:15 PM   #4
romeojk27's Avatar
Rewards Points: 14
Hi, I am not sure but think maybe you are doing something like in this picture. If you are I suggest you follow rrbuildings on instagram and take a look at what they do and ask them. They have some amazing pictures and videos of the strength of the brackets they use. I hope this helps...
romeojk27 is offline   Reply With Quote
Old 09-08-2018, 08:36 AM   #5
Rewards Points: 4
I'm trying to achieve this look. The concrete is approx 3' down but the saddle has only one rebar post that is 6" into the concrete. The "decorative stuff" on top would be 2x6 joists between 3-4' long with 2x2 spindles for decoration across the top. A 2x10 beam posted on front and back of post would run the length of house and attach to all four posts approx 8-10' apart.
My big concern is the sway. As the saddle was set in the direction it was I would allow for sway into house or out onto deck.
Old 09-08-2018, 08:36 AM   #6
Rewards Points: 46
If in post # 4 that red string line is where the bottom of the saddle needs to be ..oh boy, someone got their sonotube too low.
romeojk27 likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 09-08-2018, 09:11 AM   #7
retired framer
There is a cheat that will get you there.
Add a 2x6 to one side of the bottom of the post to space it out the side of the concrete,
Add a 4" steel C channel about 30" to that side with 2 lag bolts into the post and 2 anchors into the concrete.
https://www.discountsteel.com/items/..._C_Channel.cfm
Old 09-08-2018, 11:09 PM   #8
romeojk27's Avatar
Rewards Points: 14
You are right! But It’s not for the bottom, it’s to keep them straight
Gregsoldtruck79 likes this.
Laying concrete around deck posts. smartsid Concrete, Stone & Masonry 10 09-13-2016 04:51 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Adding posts and beam to floor for aquarium Vincer Building & Construction 4 03-23-2011 03:47 PM
Fastening deck posts to concrete spaceman spif Carpentry 6 10-11-2010 07:09 PM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 03:14 PM
