Any Solid Wood Behind Hollow Doors? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-25-2013, 10:41 PM   #1
Rewards Points: 2,442
Any solid wood behind hollow doors?
I am trying to hang a robe hook on this door and I thought there is going to be some solid wood behind it somewhere...
but I drilled where I marked A, B, C and hit nothing but air.
Is the entire door hollow besides the 4 edges? There has to be somewhere in the middle I can drill and hit something solid, right?
miamicuse is offline   Reply With Quote
Old 11-25-2013, 11:07 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,102
Just a honey comb of cardboard with 2 panels glued to the front and back.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
gregzoll (11-26-2013), miamicuse (11-26-2013)
Old 11-25-2013, 11:12 PM   #3
Rewards Points: 18,118
There's nothing solid in that type door.
You could run a machine screw through the door with a washer or a screw meant for drawer pulls with a large head.
Old 11-25-2013, 11:34 PM   #4
Registered User
Rewards Points: 526
Usually a 1-1/4" solid wood frame around perimeter of the door is all..... maybe wider at the hinges.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 11-26-2013, 12:28 AM   #5
"Just a honey comb of cardboard"...really?
I knew it's hollow but I thought there is some solid member along the middle or at least MDF I didn't expect anything except the edges to be air.
Well that's a new one.
Old 11-26-2013, 03:09 AM   #6
iminaquagmire's Avatar
Rewards Points: 338
They do make hollow core door anchors. They should hold a robe just fine.
iminaquagmire is offline   Reply With Quote
Old 11-26-2013, 06:06 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 9,974
I would use one of those stick on hooks.....they make some that work really well. One of the keys to it sticking is making sure that the surface is clean of any oil and dirt.
We just received the interior doors for your addition....non of that hollow stuff....these are solid knotty Alder
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
jbfan (11-26-2013)
Old 11-26-2013, 09:55 AM   #8
hmmm...it would look a little weird with washers.
May be I'll use drawer pulls - some drawer pulls "look" like hooks upside down with a single screw.
If I put the one draw pull on each side of the door and put in a threaded rod of the right length, I may be able to secure one on both ends by spinning them into place.
Old 11-26-2013, 09:56 AM   #9
Solid wood door rocks!
Old 11-26-2013, 09:59 AM   #10
JOATMON
ddawg16's Avatar
BTW.....those doors with frames were around $300 each.....or, about $200 more than a cheap stamped door.....but I won't get tired of these in 5 years....
install used wood french doors subvet Windows and Doors 16 02-17-2012 07:53 PM
Sound insulation: Changing interior hollow core door to solid core, or exterior door? aminus21 Building & Construction 1 03-10-2011 01:43 AM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 04:48 PM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 02:27 PM
Painting Old Hollow Doors diywoman Painting 12 02-02-2007 07:52 AM
