Any Popcorn Ceiling Experience ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-07-2015, 02:32 PM   #1
I'm hoping there are some popcorn ceiling experts on this forum.
I have a smoke stained, dirty popcorn ceiling I want to keep if possible. I do not think it has ever been painted. I am planning on using a roller as I do not have a paint sprayer.
I am kinda afraid of what may be found under the popcorn as my house was built in the 50's, so removing it will be my last option and a can of worms I'm not prepared for.
While dusting it to start the painting process some (just a bit) of the popcorn has flaked off. I used a soft broom with light pressure. Is this normal?
Can the ceiling be painted even though some is flaking off?
Will proper rolling will Zinsser oil base stain blocker then with regular ceiling paint adhere well? Also is there a better product for this than Zinsser? The room is only 12 x 14, so I'm open to buying several cans of spray primer if that would be a good idea???
I will appreciate any comments good or bad, thank you.
Dixiebrook is offline   Reply With Quote
Old 07-07-2015, 03:04 PM   #2
Rewards Points: 107
I have successfully painted popcorn ceilings. You have to be careful for the first couple of coats. Each coat, roll in one direction And don't roll over where you already painted. It's really loose and falling off then you must address that fiest
jimn01 is offline   Reply With Quote
Old 07-07-2015, 03:44 PM   #3
Rewards Points: 18,118
Now would be a good time to get rid of that pop corn.
Then you would not have to keep dealing with an impossable to clean, dust trap of a ceiling.
Old 07-07-2015, 09:08 PM   #4
Rewards Points: 6,236
Water is what we use to remove popcorn, so guess what happens when you roll on latex (WATER based paint.) Can it be painted yes but it should be sealed with something like Gardz or Rx35. And maybe rent a sprayer. Keep one thing in mind, at this point removal is pretty simple and cheap. Once painted the removal becomes much harder and more expensive.
Entering your general location can help with answering a lot of times
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (07-07-2015)
Old 07-08-2015, 03:10 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 2
agreed, but if you must keep it, I would go the spray can route
chrisn is online now   Reply With Quote
Old 07-08-2015, 07:25 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,574
There are some good videos on here an YouTube by a regular contributor on here. Look in the sticky sections of the threads.
Old 07-11-2015, 07:21 PM   #7
Well I took the popcorn off, it was very easy. I sprayed water, waited, scraped. The popcorn was sprayed directly on the drywall.
Now.........should the drywall be sealed before I use joint compound to make some type of texture for the ceiling?
Old 07-11-2015, 09:52 PM   #8
No it doesn't need to be sealed. But you may want to repair any gouges left from the removal Depending on what texture you use it may not cover everything. In fact I usually skim coat the ceiling after removal.
Old 07-11-2015, 10:24 PM   #9
Here it is. SirMixAlot.
https://www.youtube.com/watch?v=Fz63ATjiVdY
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
kwikfishron (07-11-2015), ToolSeeker (07-12-2015)
Popcorn Ceiling Rant... DrHicks General DIY Discussions 25 04-18-2012 08:03 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Painting a wall that butts up against a popcorn ceiling... hikerguy Painting 9 08-07-2011 02:56 PM
Crazy popcorn ceiling JamesN Drywall & Plaster 9 01-14-2011 01:30 AM
popcorn ceiling debd General DIY Discussions 5 11-06-2008 04:25 AM
