Air Seal Attic - Drywall And Top Plate - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Dave Sal
Old 11-22-2018, 12:09 PM   #1
Rewards Points: 4
Air seal attic - Drywall and top plate
I am working adding insulation to the attic. Here is what I have.
1. About 3 inches of brown insulation stuff. It must be from the day it was built in 1979
2. Living room has aluminium foil faced top plate. Kitchen has normal top plate.
3. Gap between drywall and top plate is not sealed.
Can I use siliconized acrylic latex caulk to seal the gap ?
Can I put faced batt insulation over aluminium foil top plate ?
VSK
attic_leak is offline   Reply With Quote
Old 11-22-2018, 12:45 PM   #2
retired framer
Rewards Points: 6,256
Re: Air seal attic - Drywall and top plate
VSK
Can you post some pictures?
Old 11-22-2018, 01:21 PM   #3
Rewards Points: 4
pics with aluminium foil, without aluminium foil, current insulation and joist height.
Air seal attic - Drywall and top plate-img_20181122_121440-1-.jpg   Air seal attic - Drywall and top plate-img_20181122_121455-1-.jpg   Air seal attic - Drywall and top plate-img_20181122_121510-1-.jpg   Air seal attic - Drywall and top plate-img_20181122_121522-1-.jpg
Old 11-22-2018, 01:44 PM   #4
retired framer
Usually those cracks between wood and dry wall are covered with another 2x4 or 2x6 that we call drywall backing .
If the seams were filled on the other side you would not expect an air leak, but caulking it would not hurt either. I am not sure the best caulk for that, Bud should be along with that info.
Hope you are also looking at venting.
Old 11-22-2018, 01:58 PM   #5
Dave Sal's Avatar
Rewards Points: 366
Not an answer to your question but thought I'd mention it anyway. My house was also built in 1979 and I had about the same amount of blown in insulation as you. After a couple of years I added R-19 rolls across the joists and cut my heating bill in half the next winter.
Nealtw likes this.
Dave Sal is offline   Reply With Quote
Old 11-23-2018, 09:26 AM   #6
Rewards Points: 4
Are the gaps big enough to seal with spray foam? Off the shelf caulk will shrink on gaps bigger than 3/16".
The batt insulation is a very good idea. More of a barrier to cold.
Sent from my VS988 using Tapatalk
t.carpenter00 is offline   Reply With Quote
