Advantech “reference Corner”? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-09-2019, 02:51 PM   #1
Rewards Points: 282
Advantech “reference corner”?
I’m about to put in some Advantech subfloors and I noticed one corner says “reference corner.” I have no idea what this means. It’s OSB, so all the corners are going to be square. Anyone know what this means?
eholmes77 is offline   Reply With Quote
Old 03-09-2019, 03:18 PM   #2
retired framer
Rewards Points: 6,362
Re: Advantech “reference corner”?
Is that on the corner with the grove side?
Do not use flat bottom gables with scissor trusses.
Old 03-09-2019, 03:22 PM   #3
Rewards Points: 282
Weirdly it’s the one with the tongue. It would make more sense the other way around. The installation instructions don’t even mention it so I’m inclined to ignore it.
Old 03-09-2019, 03:30 PM   #4
retired framer
Can't tell you many floor I have done and never noticed that,
Measure out at both ends of the space and mark the joists the width of the board and snap a line so you can check the length of the space to be sure all the boards will fit and line up, you working edge is the groove, put a 2x6 in front of it so you can hammer it in, they are designed to not quit go together.
Old 03-09-2019, 03:32 PM   #5
retired framer
Perhaps there is a lump there to force you to leave a gap between the ends of the sheets.
Old 03-09-2019, 03:32 PM   #6
Rewards Points: 282
That’s what I figured. Thanks.
Difference between Advantech 'flooring' and 'sheathing'? NatRussel Flooring 3 05-21-2018 05:41 PM
Commercial vinyl tiles over Advantech subfloor Arky217 Flooring 5 11-27-2012 11:44 PM
Advantech or Plywood? remoder Flooring 7 09-29-2012 04:56 PM
Old Floor / Tar-Paper / Advantech bobjones00 Flooring 4 10-19-2009 05:08 PM
Advantech Flooring eis61374 Flooring 2 10-05-2008 02:38 PM
