Acrylic "glass" For Kitchen Cabinet Doors - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree10Likes
Old 01-24-2019, 02:04 PM   #1
Rewards Points: 130
Acrylic "glass" for kitchen cabinet doors
We're getting ready to replace our kitchen cabinet doors, some of which will have "glass" panes in them. For safety, etc., we're planning on acrylic rather than real glass for the panes.
From looking at plastics suppliers online, I see both extruded & cast acrylic sheet material. Which should I choose?
And what's a good thickness of plastic to use?
I'm sure I can get recommendations from whichever supplier I go to, but I like to have some idea of what I'm in for head of time.
Thanks for any comments/suggestions!
stevedore is offline   Reply With Quote
Old 01-24-2019, 02:38 PM   #2
Rewards Points: 9,262
Re: Acrylic "glass" for kitchen cabinet doors
For a cabinet door, I don't think it matters. Get the cheaper one -- I think that would be extruded.
About 1/4" would be best. But note that often the actual thickness is different (and less) than the nominal thickness. (i.e they call it 1/4", but when you get it, its about .22")
But the stuff is not cheap, so you may go thinner just to save some bucks.
SPS-1 is offline   Reply With Quote
Old 01-24-2019, 03:02 PM   #3
Two Knots's Avatar
Rewards Points: 4,899
We only use real safety glass in cabinets and other projects.
Plastic dulls and scratches easily. We only used plexi-glass on the back
of two birdcages, itís dull, but we needed it to be plastic cause we take
It off and on for cleaning.
If you silicone the glass into the routed channel,
it will be safe.
dd57chevy and Domo like this.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is online now   Reply With Quote
Old 01-24-2019, 05:25 PM   #4
Rewards Points: 516
1/8 glass doesn't break that easily. But if you're set on plexiglass, 1/8 plexi is strong enough. I made a simple kitchen wall cab as such. Then I just held the glass (plexi in your case) with glazing points. Rabbeted part was stained the same as face.
Below image was a mistake. I thought you can use it, but when you route out the back, can't use a flush clip.
carpdad is offline   Reply With Quote
Old 01-24-2019, 06:08 PM   #5
dd57chevy's Avatar
Rewards Points: 2,840
The acrylic sheets have much more flex the thinner you go . What they sell as 1/8" (I think it is now actually .118) would be my choice if your door will accept it .
dd57chevy is offline   Reply With Quote
Old 01-24-2019, 10:35 PM   #6
Msradell's Avatar
Rewards Points: 972
If you're going the plastic route use Lexan instead of Plexiglas. It's a much better material.
BigJim and rander101 like this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 01-25-2019, 09:35 AM   #7
Lexan = one company's trade name for polycarbonate
Plexiglas = one company's trade name for acrylic
Indeed polycarbonate is harder than acrylic. Also more expensive.
Old 01-25-2019, 09:51 AM   #8
Mystriss's Avatar
Rewards Points: 4,688
I've used a lot of plexi & acrylic in my computer modding to make custom case windows & LED motherboard trays:
Its an older mod, but I think it was 6mm (1/2 inch) thick. I much prefer the cast acrylic, and use this brand, Acrycast but I don't think they do bigger sheets than 12x12 inch ( https://www.amazon.com/s/ref=sr_pg_1...qid=1548428691 ):
I used to use this stuff and still have a huge sheet of it in the garage. It doesn't cut nor finish as well, but I think it'd probably work for your windows. (That said, I haven't tested it, but I do have the impression that it scratches easier. Not like "Oh I touched it and it scratched" kind of thing, but as the top of a computer case. It might be alright for your cabinet windows.)
dd57chevy likes this.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old 01-25-2019, 10:01 AM   #9
Mystriss's Avatar
Oh and as a note, if you've got curved cabinets/windows/panes you'll want to go with the thinner stuff, 3mm (1/8") I believe, so you can bend it with a heatgun. I used a cement molding tube to make this acrylic cover plate IIRC, wasn't perfectly shaped due to not having a good heatgun, but it still looks great when installed.
Acrylic "glass" for kitchen cabinet doors-adscn0114.jpgAcrylic "glass" for kitchen cabinet doors-adscn9813.pngAcrylic "glass" for kitchen cabinet doors-adscn0134.jpg
I've also done a clear curved window on one of my carousel horse displays that the glass broke on (or maybe I should say my son accidentally threw something through) but I don't have a decent picture of it and it's kinda buried under donation boxes atm.
Old 01-25-2019, 01:08 PM   #10
Rewards Points: 130
Thanks for the replies. We're going to reconsider using real glass rather than acrylic; I'm probably overly worried about breakage. I'm installing soft-close hinges, so there won't be any slamming to worry about.
Just as a point of information, from what I read Lexan would not seem to the best non-glass material to use for these doors. It scratches more easily, isn't as stiff, and is more likely to yellow with age when compared to acrylic. And as someone mentioned, it's more expensive.
Thanks again for your thoughts & comments.
Old 01-25-2019, 02:44 PM   #11
Mystriss's Avatar
If you have a glass window/auto window store, or sometimes even a picture framing place, around, they might have glass at a decent price and stained glass cutters are fairly inexpensive. A stained glass store has clear glass too, but they'll charge a lot more - on the other hand, they have a lot of really cool glass you might want to use in your cabinets. Use Dremel wheel sanding drum with around 320 grit for a smooth edge (do that outside/in the garage and wear a mask as it'd be like breathing in volcano ash.)
Old 01-25-2019, 09:01 PM   #12
Rewards Points: 2,941
My TV stand has tempered glass panes that are only 1/8". I have two sons. The regularly slam them and crash dump trucks into them and stuff. They are pretty darn tough.
Another cool thing about tempered glass is that if it does break, it disintegrates into pieces the size of a pencil eraser. It is more like scooping up a handful of gravel than sharp glass.
Safety glass is even stronger. One of my customers had her house broken into. She had a glass patio door on the inside of her house and kept it locked. The unfortunate bad guy broke in on the wrong side of the patio doors. But he was already inside, so he had plenty of time to work. There were hundreds of marks all over them from him trying to smash the glass with different things. It was comical. He finally got in, but only by ripping the whole door out of the frame!
Glass is not inherently unsafe, but you kind of have to know what you're doing.
dd57chevy and Mystriss like this.
mathmonger is online now   Reply With Quote
Old 01-25-2019, 09:37 PM   #13
I was checking out some Lexan the other day in Home Depot. They say it is 250x stronger than glass. It looks nice too. I dunno. It's on my list.
Old 01-26-2019, 07:14 AM   #14
You can probably bend it 250 x more than you can bend glass. But is softer and can scratch. Harder than acrylic though.
Old 01-26-2019, 01:13 PM   #15
Can you use it outside?
Customed Milled Doors - Advice Needed about Errors Rubespur General DIY Discussions 7 03-23-2018 08:31 AM
Kitchen Cabinet Doors Peeling peequi Kitchen & Bath Remodeling 3 10-16-2014 12:06 PM
Cabinet doors gruntman Carpentry 7 02-22-2014 03:14 PM
frustrated with cabinet doors TrailerParadise Carpentry 1 09-19-2013 10:20 AM
kitchen cabinet doors lawbm Kitchen & Bath Remodeling 1 11-20-2011 09:13 AM
