Jaye's No Fail Fried Chicken - Cook It Yourself - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Cook It Yourself
Like Tree6Likes
  • 1 Post By ajaye
  • 1 Post By Startingover
  • 1 Post By XSleeper
  • 1 Post By de-nagorg
  • 1 Post By ajaye
  • 1 Post By DoomsDave
Old 06-21-2020, 08:52 PM   #1
Rewards Points: 648
So I been playing around with this for a while, and yesterday did this version, chicken was so moist sorry about the pics as daughter hit the plate with ketchup before I could get a pic.
I thought about how we make "fish shop fish" and instead of using a dry rub, I worked on a wet and dry rub.
The wet rub makes the chicken stay really moist.
Now you COULD use a deep fat fryer, but no-need a deep frying pan works the same.
BUT you need a food thermometer to check the temp of the chicken
also use a medium heat, to take it up slowly to temp, HOT OIL, Canola or similar.
We also had fried bell peppers which I cut into strips and fried in a mixture of coconut oil and butter
Adrian's Fried Chicken
This works well because you have a dry and a wet mixture, kinda like a fish batter and this keeps the chicken moist.
Ingredients:
4 cups flour
2 tablespoons salt
1 1/2 teaspoons pepper
1 tablespoon paprika
2 eggs
11/2 cups water
21/2 teaspoons dried sage powder
CHICKEN DRUMSTICKS !
Method:
1> Mix the following into a large mixing bowl ( 2 2/3 cups of the flour / 1 tablespoon salt, paprika, 2 teaspoons pepper)
2> In a deep tray, make the wet mix (beat the eggs, add water, rest of the salt, rest of the flour, rest of pepper), make a thick SLURRY
3> Dredge the chicken into the wet mix, then into the flour
4> Put on a metal cookie tray or similar
5> In a frying pan heat enough oil to fill the entire pan at lest 1" or 2" or half the chicken height, use a temp probe to get the oil up to at least 375 deg's (or so it is "JUST" starting to smoke)
6> Fry the chicken, the trick is not to fill the pan, you must have plenty of space to fry, 2" or 3" between pieces, Turn after 8 minutes,
Using a temp probe, make sure the internal temp of the chicken is at LEAST 165 deg's.
6a> Keep the heat level around medium, no higher, if the temp of the chicken is not high enough, turn it over again every 7 minutes or so, you CANNOT tell if the chicken is done without a probe !
7> Put the chicken on a draining tray
8> Serve
Jaye's No Fail Fried Chicken-p1010017.jpg   Jaye's No Fail Fried Chicken-p1010018.jpg   Jaye's No Fail Fried Chicken-p1010019.jpg
Startingover likes this.
ajaye is offline   Reply With Quote
Old 06-21-2020, 09:27 PM   #2
Rewards Points: 496
Re: Jaye's No Fail Fried Chicken
Looks tasty.
ajaye likes this.
Startingover is online now   Reply With Quote
Old 06-21-2020, 09:30 PM   #3
Rewards Points: 1,713
Good enough to eat. But I'd need about 8 more legs!
PS, my secret ingredient is white pepper.
ajaye likes this.
XSleeper is offline   Reply With Quote
Old 06-21-2020, 09:32 PM   #4
JUSTA MEMBER
Rewards Points: 3,774
Looks good, except for that splotch of red garbage on there.
You won't find any of that junk in my kitchen.
ED
ajaye likes this.
de-nagorg is online now   Reply With Quote
Old 06-21-2020, 09:37 PM   #5
Rewards Points: 648
ohhh maybe I'll try it with that next time
de-nagorg likes this.
Old 06-21-2020, 10:41 PM   #6
DoomsDave's Avatar
Rewards Points: 13,696
Oh my gahd
Licking the computer screen . . . . .
ajaye likes this.
Life is one long teaching moment.
DoomsDave is offline   Reply With Quote
The Following User Says Thank You to DoomsDave For This Useful Post:
ajaye (06-22-2020)
