Why Do You Prefer To Do It Yourself? - Featured Topics - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Featured Topics
Like Tree35Likes
Old 03-05-2019, 11:41 AM   #31
retired painter
Rewards Points: 526
Re: Why Do You Prefer To Do It Yourself?
MH doors are generally standard widths but most are only 76" tall instead of 82" I usually just by a slab door and cut off whatever I need to off of the bottom. That also requires ripping a piece of 2x to insert at the bottom.
MH cabinets are junk. I built cabinets for my kitchen and they came out great. I'm currently building 4 for my shop and I keep making one mistake after another
mark sr is online now   Reply With Quote
Old 03-05-2019, 01:08 PM   #32
Rewards Points: 210
I think the newer ones might be but mine are directly screwed into the "studs." The jamb on the latch side is about 4 strips of the cardboard walls stapled into the other "stud." A regular prehung door size doesn't fit so I ripped the walls apart and reframed so one would fit.
They are, I don't even have backs and can't believe how long they have survived. Frames are just veneered particleboard and the doors...idk, look like mitered frames with a skin on the front and back.
Certainly a trial and error game for the first couple but after sitting down and doing all the math for the bit set, making setup blocks and making a cheat sheet I can make the doors easily now. The frames and boxes are another ball of wax though, use sketchup to play with the dimensions and what works. I get the door dimensions from the sketch and plug that into my cheat sheet to get the cut sizes. Takes time but saves on the amount of firewood I used to make. Best of luck!
Fish_Stick is offline   Reply With Quote
Old 03-05-2019, 03:21 PM   #33
retired painter
Rewards Points: 526
No, you can't use prehungs in a MH without reframing [maybe the whole wall] I was referring to slabs that you'd cut the height down and then use the existing jamb. Many MH interior walls aren't 2x4 construction.
Old 06-12-2019, 01:16 AM   #34
Rewards Points: 78
Being able to do things on my own and not having to rely on money all the time to fix things have been strongly inculcated in me by my parents, partly because they did not have a comfortable upbringing. Honestly, I am thankful for it even when money is no longer a problem (at least it isn't now) and in a way hiring others would also be helping them make a living. Recently I employed the help of a landscaper, got curious about the job and learned that they earn an average of $13 per hour (source). But being able to do things personally is more than just saving money, there is also satisfaction and peace in knowing that I'll do fine on my own.
Dave Sal and Drachenfire like this.
jecapereca is offline   Reply With Quote
Old 06-12-2019, 11:24 PM   #35
Hammered Thumb
Rewards Points: 1,268
Originally Posted by HandyAndyInNC View Post
I took the electric from 60 amp to 800 amp service
I installed a 2" copper supply from the street
Wait, timeout from the regularly scheduled thread. 800amp? I don't even think I can get over 400a for single family residential. 2" water meter too? Are you paying commercial rates for those (here a 2" meter would be $230 more per month before water use charges!)? Are you a bitcoin miner bottling water on the side?
3onthetree is offline   Reply With Quote
Do you prefer video or text? CaptTom Off Topic 18 01-29-2019 05:09 AM
What Type Of Home Decor Do You Prefer? Cricket Off Topic 10 06-09-2014 05:01 PM
What kind of ABS or PVC pipe cutter do you prefer Pirulo Plumbing 10 09-18-2012 12:12 AM
prefer crimp or wirenut grounds? redline9k Electrical 2 03-16-2011 02:54 PM
Floor or wall registers- which do you prefer? project_guy HVAC 5 01-29-2010 01:53 PM
