Can YOU Unclog Your Own Drains? - Featured Topics - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > Featured Topics
Like Tree47Likes
Old 05-15-2018, 11:50 AM   #31
Oso954's Avatar
Rewards Points: 704
Re: Can YOU Unclog Your Own Drains?
Next thing to know is that all bath room sinks and tubs have an overflows.
Bathroom sinks come both ways, with or without overflows.
When you are installing the drain pipe/popup assembly, you need to get the right one for the sink that you are working on.
As many of the non-overflow sinks are thinner at the drain hole area, putting an overflow drain in a non-overflow sink will often make a mess in the vanity or on the floor.
Oso954 is offline   Reply With Quote
Old 06-15-2018, 01:28 PM   #32
Rewards Points: 749
I am a large construction plumber and will not rent and run a machine myself. My brother in law did a favor and the machine they rented had a coupling at 75 feet which broke. That favor turned into a 5k backyard dig up and replace.
If i ever have a clog i cant get my my plunger or little toilet snake i will call a guy with a machine. Knock on wood i have yet to have to call a sewer guy in.
ct18 is offline   Reply With Quote
Old 06-15-2018, 11:12 PM   #33
Rewards Points: 982
1/3 of baking soda and 1/3 of vinegar = 2/3. What is the other 1/3 to finish the solution?
Nik333 likes this.
fireguy is offline   Reply With Quote
Old 06-15-2018, 11:25 PM   #34
JUSTA MEMBER
Rewards Points: 1,160
Water?
Vinegar and baking soda are going to make a fizzy smelly mess.
An acid and a base, will make a lot of fizz, Vinegar= Acetic acid, Baking soda + sodium bi-carbonate, a base.
And water to liquify it.
A soda fire extinguisher is one example of this.
ED
de-nagorg is online now   Reply With Quote
Old 06-16-2018, 12:08 AM   #35
Rewards Points: 14
I bought a 'Zip-it' at a hardware store for a couple dollars and so far (knock on wood) that has worked to unclog the bath tub and bathroom sink drains when they start draining slowly. It pulls all of the hair out of the drain.
Nik333 and Yodaman like this.
gma2rjc is offline   Reply With Quote
Old 06-16-2018, 12:21 PM   #36
Likes to learn
cat's_pajamas's Avatar
Location: Sierra Nevada Mountains in Central California
I bought one awhile back and have found it really handy in both my bathroom sink and shower drain. I carefully(!) [very sharp, saw-like teeth on it]) clean it off after use even though the package says it should be tossed after one use because of the danger of cutting yourself trying to clean it.
I also removed the pop-up stopper in the bathroom sink because it let too much hair/debris down into the drain and caused blockages. I replaced it with one of those little mesh drain strainers.
gma2rjc and de-nagorg like this.
cat's_pajamas is offline   Reply With Quote
Old 07-18-2018, 12:49 AM   #37
Rewards Points: 296
I use a plunger in all the sinks about every 3 months. You would be surprised how much hair comes up. I consider it an ounce of prevention.
I would never call a plumber. It's too easy and if it was really stopped up, I would just remove the trap at the bottom of the sink. But it's surprising how many people
(grown men ) are intimidated by something like this....
DallasCowboys is offline   Reply With Quote
NO Traps in Basement Floor Drains IrwinRedtail Plumbing 3 02-04-2012 06:22 PM
Need to unclog drains outside of pool EkS Plumbing 8 08-18-2010 12:39 PM
Clogged Drains Willie5566 Plumbing 19 02-17-2009 09:45 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
replacing old galvanized drains drewhart Plumbing 18 07-20-2008 01:14 PM
