Ye Olde Garage-adding Joists. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 09:53 PM   #1
Ye Olde Garage-adding joists.
I am moving into an older(1924) home and have some issues with the garage. I have not measured but I have a strong suspicion that the walls are bowed. There are only 3 2x4's tying the walls together and they span approximately 17ft at some time someone has wedged some 4x4 posts to prevent sagging. I am thinking of putting in 2x10's and supporting them with a beam and posts to try and tie it all together. My question is should I try to pull the walls back in? And if so ,how? It's a single car garage but wide with a curved roof on one side, but pretty weak looking by modern standards. Walls are stucco roof is comp over wood shingle.
DaleBelcher2 is offline   Reply With Quote
Old 07-11-2010, 12:41 AM   #2
Is the garage attached or detached?
Troglodyte is offline   Reply With Quote
Old 07-11-2010, 07:06 AM   #3
It's detached.
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 10:32 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Adding supports for beams and joists pinkertonpv General DIY Discussions 2 08-13-2008 02:04 PM
