XPS Foam OSB Screw Pattern? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 09:29 AM   #1
XPS foam OSB Screw pattern?
I know I read on this website the screw pattern/number of screws for attaching the XPS foam and TG OSB to my basement floor, but cant seem to find it again.
Can somebody provide me with the screw pattern and number of screws per 4x8 sheet?
ctkeebler is offline   Reply With Quote
Old 12-06-2009, 01:46 PM   #2
Is there a minimum number of screws I should use? I was thinking 9 per board as a minimum. 3 rows of three?
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
