Wood Replacement Under Threshold? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2016, 10:11 PM   #1
Rewards Points: 2
I just purchased a home that has a back door with two windows on either side. I pulled out some rotted wood under the threshold coming into the house. Is there something I can put underneath the threshold to replace this wood? I would need something that would stop moisture from coming in. Is there some type of epoxy or something that I can put underneath this? I'm wanting to avoid replacing the entire threshold, as it goes underneath the windows on either side and would be a real pain to replace. Please see the attached image and picture it with no wood. Thanks for all answers.
Andrew19 is offline   Reply With Quote
Old 02-17-2016, 09:00 PM   #2
Rewards Points: 1,036
You can get all aluminium or one with synthetic wood. Your best bet would be to find a door shop/supplier in your area.
here is a manufacturer link.
http://www.pemko.com/index.cfm?event...uctMaterialId=
I would bet you need to replace the entire jamb. Make sure you flash it properly and install a pan or flash it correctly at the bottom or you will be replacing more than a door in the near future.
This video is the best demonstration of how to properly flash a door i have came across. you may not have the same materials available but you should be able to adapt to what ever product you are using.
Mingledtrash is offline   Reply With Quote
Old 02-18-2016, 08:45 AM   #3
Rewards Points: 18,382
Post a picture of the outside when you can.
In most cases the reason this happens is a slab, stoop, deck, was built even with the threshold, or as mentioned there was no or improper flashing which is a big building 101 mistake and a sure way to have moisture damage.
replacement door frames, wood vs vinyl raylo32 Building & Construction 0 09-29-2015 02:43 PM
Help with wood fence gate replacement DEL82 Landscaping & Lawn Care 3 07-05-2015 06:18 PM
Need an exterior door wood threshold golfgod04 Carpentry 11 06-23-2015 11:06 PM
Basement Access Door Replacement...Sealing Under Threshold. mgh-pa Windows and Doors 2 09-13-2014 10:54 PM
Installing Replacement Window and Existing Wood Siding Trooper0999 Windows and Doors 2 05-19-2014 09:51 AM
