Window Leak: Flashing Or Window? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 12:32 PM   #16
Registered User
Rewards Points: 526
And we are riding Loneframer's in #2........ lol.
Lack of a fastener at the bottom fin corner , knife cut section removed nailing fin, a horizontal joint in the osb where you least want it for water intrusion, over driven pneumatic staples in osb, perforated house wrap (as Framerman said) rather than a drainage house wrap, 1/4" only lap (scary) on Hardie siding, cut ends not primed- not per manuf.'s install- the whole wall may leak not just the window- with any wind-driven rain, I think more is wrong than pictured..... I'd question the whole application.
http://www.eima.com/pdfs/The%20Perfe...r%20Stucco.pdf
http://www.coastalcontractor.net/cgi...ticle.pl?id=14
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tom Struble (08-31-2010)
Old 08-31-2010, 12:46 PM   #17
Tom Struble's Avatar
Rewards Points: 2,002
well...yea i been riding his for years
Tom Struble is offline   Reply With Quote
Window leak handyandi Building & Construction 3 08-04-2010 07:13 PM
window leak c00rdb General DIY Discussions 11 03-03-2010 06:29 AM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Window Flashing compromised Rubu Building & Construction 4 10-09-2008 04:39 PM
