Will This Shelf Design Hold The Load Safely? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2017, 03:27 PM   #1
Rewards Points: 14
Will this shelf design hold the load safely?
Hi all,
I'm installing some shelving to support some 10 gallon fish tank. The tanks themselves should weigh 80-100lbs max when full. I'm using these heavy duty brackets that say they can support 1000 lbs when "installed properly", just not sure what that means :-). I'm planning to use two of them per tank, spaced 16" apart, installed directly into studs. The tanks are 22 inches wide and will sit on 3/4 plywood on top of the brackets. I'm using 1 1/2 inch long lag screws with washers.
I guess my first question is, how is the weight distributed in this setup? is all of the weight on the lag bolts and 2x4 studs? Should the screws be longer? I'm not too worried about the brackets but how I can be sure the screws or 2x4s will not break?
Here's a detailed sketch I made along with info on the brackets. I'm not an engineer but enjoy DIY and want to make sure this is absolutely safe from crashing 4x10 gallons of saltwater on my floor
bh750 is offline   Reply With Quote
Old 04-26-2017, 03:30 PM   #2
Rewards Points: 14
Re: Will this shelf design hold the load safely?
Sorry, its not allowing me to post links to images just yet.
Old 04-26-2017, 03:33 PM   #3
Rewards Points: 14
Bracket
Sketch
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 11:09 AM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 11:14 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Help 30 amp Load center for my HID lights and miscellaneous [email protected]@ Electrical 9 03-06-2010 12:49 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
