Why Won't Generator Start? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 11-04-2019, 07:17 PM   #1
Rewards Points: 110
Why won't generator start?
Brand new generator. Just bought it today.
Oil is full. Gas is full. All levers are in the proper position.
Does it look like I'm not pulling hard enough? I think I am.
https://www.dropbox.com/s/4qottdvpy5...91359.mp4?dl=0
farmerjohn1324 is offline   Reply With Quote
Old 11-04-2019, 07:19 PM   #2
retired framer
Rewards Points: 6,198
Re: Why won't generator start?
Is there a valve to turn on the fuel?
Do not use flat bottom gables with scissor trusses.
Old 11-04-2019, 07:20 PM   #3
Rewards Points: 110
Like this?
Old 11-04-2019, 07:23 PM   #4
Rewards Points: 4
Thatís your kill switch
Retired guy from Southern Manitoba, Canada.
660catman is online now   Reply With Quote
Old 11-04-2019, 07:24 PM   #5
retired framer
It will be somewhere on the fuel line
https://www.google.ca/search?q=gener...w=1093&bih=502
Old 11-04-2019, 07:32 PM   #6
Rewards Points: 110
Originally Posted by 660catman View Post
That’s your kill switch
Is this it?
Old 11-04-2019, 07:35 PM   #7
Rewards Points: 110
https://www.dropbox.com/s/dpphiznlja...93353.mp4?dl=0
Does this tell you anything?
Old 11-04-2019, 07:35 PM   #8
Rewards Points: 4
Is there not a valve right behind there like what Nealtw posted
Old 11-04-2019, 07:36 PM   #9
retired framer
All the way left is closed all the way right is open.
Old 11-04-2019, 07:38 PM   #10
Rewards Points: 4
All that lever would be doing is setting carb to choke(start) and run. Off position shuts it off.
Old 11-04-2019, 07:39 PM   #11
Rewards Points: 110
I tried it like it's supposed to be.
Old 11-04-2019, 07:45 PM   #12
retired framer
Do you have the manual for it?
Old 11-04-2019, 07:46 PM   #13
Rewards Points: 110
Is there a missing link between these 2 things?
https://www.dropbox.com/s/bj6y2xz2cx...93755.mp4?dl=0
https://www.dropbox.com/s/f7rzuvpwgm...93742.mp4?dl=0
Old 11-04-2019, 07:46 PM   #14
Rewards Points: 4
Iím thinking you may not have a valve if you have the 3 positions for that lever. My Champion has a fuel shutoff but only choke or run on the lever.
Bud9051 likes this.
Old 11-04-2019, 07:46 PM   #15
Rewards Points: 110
Following it exactly.
