Where Do I Start - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 12:22 AM   #1
where do i start
new property owners need to have electric and water run where do i start and how much of this can we do ourselves live under kentucky laws
wright is offline   Reply With Quote
Old 03-06-2010, 12:51 AM   #2
Unless you are an licensed electrician and plumber, none of it. Get both licensed trades to pull permits and do the work / get inspections where mandated.
I am by no means trying to be a d#ck about this, I understand both trades extremely well by default working side by side. Does not qualify me in the slightest to do it. Very technical and very dangerous at times.
Good luck.
lemon714 is offline   Reply With Quote
Old 03-06-2010, 09:46 AM   #3
Are you saying its illegal in Kentucky for a homeowner to DIY electric or plumbing ?
In MA we are not allowed to do plumbing
Old 03-06-2010, 09:57 AM   #4
Civil Engineer
Rewards Points: 5,246
I am not certain the rules are quite that inflexible. Even in Massachusetts, where only the power company can actually install power up to your house, you are permitted to dig your own trench if you want underground power. Depending on the POCO, you may even be allowed to furnish (probablynot install) the conduit.
As for water, I think the rules in MA are that you can dig your own trench, but the water district is going to require that a licensed contractor actually make the connection to their water supply system. As to the physical installation of the pipe to the house, I have not personally seen a water district allow the homeowner to install their own pipe up to the house, but perhaps in KY the rules are more flexible.
The best way to get an answer is to contact your water supply district and your power company. They have the final say in how it goes.
Old 03-06-2010, 10:18 AM   #5
Where I live in Pa. you can do all your owne work as long as it will pass inspection.I ran my water line from the house to the street where the water company did the final hookup.I also did the electric for my home but did hire a lic electrician to check it all and do the boxes befor the inspection.So what I am tell you Wright is you need to check your local code to see what you can do and what you cant and then do what your knowledge allows .Good luck
clasact is offline   Reply With Quote
Old 03-06-2010, 12:42 PM   #6
When I had my service feed buried I had to hire an electrician
I dug the trench (backhoe) & put the sand in
Electrician ran the conduit, wire & meter & made connections at the house
He had to leave wire at the pole w/enough slack for POCO to connect
POCO made the final connection at the pole
As stated, contact your local POCO & Building Dept to see what you can do
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 09:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 11:58 AM
Brand new PAYNE PG9MAB won't start . Error code 12 tp618 HVAC 3 12-19-2008 10:21 PM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 08:05 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 12:39 PM
