DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   where do i start (https://www.diychatroom.com/f19/where-do-i-start-66099/)
wright 03-05-2010 11:22 PM
where do i start
new property owners need to have electric and water run where do i start and how much of this can we do ourselves live under kentucky laws:)
lemon714 03-05-2010 11:51 PM
Unless you are an licensed electrician and plumber, none of it. Get both licensed trades to pull permits and do the work / get inspections where mandated.
I am by no means trying to be a d#ck about this, I understand both trades extremely well by default working side by side. Does not qualify me in the slightest to do it. Very technical and very dangerous at times.
Good luck:thumbsup:.
Scuba_Dave 03-06-2010 08:46 AM
Are you saying its illegal in Kentucky for a homeowner to DIY electric or plumbing ?
In MA we are not allowed to do plumbing
Daniel Holzman 03-06-2010 08:57 AM
I am not certain the rules are quite that inflexible. Even in Massachusetts, where only the power company can actually install power up to your house, you are permitted to dig your own trench if you want underground power. Depending on the POCO, you may even be allowed to furnish (probablynot install) the conduit.
As for water, I think the rules in MA are that you can dig your own trench, but the water district is going to require that a licensed contractor actually make the connection to their water supply system. As to the physical installation of the pipe to the house, I have not personally seen a water district allow the homeowner to install their own pipe up to the house, but perhaps in KY the rules are more flexible.
The best way to get an answer is to contact your water supply district and your power company. They have the final say in how it goes.
clasact 03-06-2010 09:18 AM
Where I live in Pa. you can do all your owne work as long as it will pass inspection.I ran my water line from the house to the street where the water company did the final hookup.I also did the electric for my home but did hire a lic electrician to check it all and do the boxes befor the inspection.So what I am tell you Wright is you need to check your local code to see what you can do and what you cant and then do what your knowledge allows .Good luck
Scuba_Dave 03-06-2010 11:42 AM
When I had my service feed buried I had to hire an electrician
I dug the trench (backhoe) & put the sand in
Electrician ran the conduit, wire & meter & made connections at the house
He had to leave wire at the pole w/enough slack for POCO to connect
POCO made the final connection at the pole
As stated, contact your local POCO & Building Dept to see what you can do
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
