What's The Name Of A Door Threshold Where Door Butts Up Against The Threshold? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2015, 06:55 PM   #1
Rewards Points: 147
What's the name of a door threshold where door butts up against the threshold?
BACKGROUND: I have a situation where there is seasonal movement of my cement slab. Consequently, the door that goes from the garage to the interior of my house, shifts! --Every spring the door binds enough so I can't close it for about 6 months. I've read where, in Denver, they have the same problem (basement floors) such that they actually build "floating walls" (and floating doors) in basements to deal with the seasonal heaving of the soil/basement floors. I am going to try this with my door problem. In learning about floating walls, on the web, I came across a door threshold wherein (a) the threshold installs under the door (like any threshold), but (b) this type of threshold is built such that part of the threshold raises up far enough so that the side of the closing door butts up against the raised portion of the threshold. Thus, the side of the door(near the very bottom of the door) is what seals the door, preventing air infiltration. With the side of the door butting up against the threshold, this allows me to let 1/4" to 3/8" of space to be between the threshold and the bottom of the door ---so the floor can shift without binding the bottom of the door! PROBLEM: For over a week I have been trying to find the website (or any website) that has those types of thresholds. ---Can't find it. I know these thresholds exists, but I can no longer find them on the web. Please help. ---Jaes.
jaes is offline   Reply With Quote
Old 08-31-2015, 08:47 PM   #2
Rewards Points: 948
It could be a bumper threshold. (I don't think it's what you want, as a threshold like you describe is a trip hazard.) I would consider an automatic door sweep.
http://www.amazon.com/Automatic-Door.../dp/B00869SOXM
http://www.hagerco.com/Product-Listi...5&SubCatID=279
keymaster is offline   Reply With Quote
Old 08-31-2015, 09:29 PM   #3
Rewards Points: 147
Thank you Keymaster. Yes! "Bumper" threshold is what I was looking for! It was so long since I saw it on the internet, that I described wrongly (it does not go under the door).
I very much appreciate the rapid response and all of the effort you put into helping me (e.g., the web links). ----- Jaes.
The Following User Says Thank You to jaes For This Useful Post:
keymaster (08-31-2015)
Old 08-31-2015, 10:23 PM   #4
Rewards Points: 948
An automatic sweep (or also a door bottom, shown below), will move up and out of the way, then close with the door to seal off drafts. It can be used with a variety of thresholds. It is self adjusting. This would be my recommended approach.
The Following User Says Thank You to keymaster For This Useful Post:
Msradell (08-31-2015)
Replace threshold? thaKing Windows and Doors 4 07-17-2012 12:27 PM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 02:20 PM
Should I chance removing this threshold? rosemonster Building & Construction 7 08-22-2010 10:34 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 06:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 08:16 PM
